brake rotor install EVO IX MR
Old Sep 14, 2007 | 06:38 AM
HesGotAnEvo's Avatar
hey guys i just got some stoptech rotors and i cant figure out how to get the calipers off ... help
Old Sep 14, 2007 | 08:12 AM
ODUB's Avatar
unbolt them, then pull
Old Sep 14, 2007 | 08:26 AM
which bolts are you talking about... are you talking about the bolts on the back of the calipers or are there other bolts that i have to take off to change out the rotors
Old Sep 14, 2007 | 08:30 AM
fastrob691's Avatar
Once you get the bolts off the rear, 17mm I believe the caliper and bracket should lift off, the rotor will come off, you may have to tap it with a rubber mallet if there is a lot of dust or rust, but all the ones I have seen just come off easy. It's basically a machined fit to the hub, around the wheel studs.
Old Sep 14, 2007 | 10:44 AM
arn't the bolts on the back of the brembo caliper hex key fasteners and i found that they were a # 9 or am i trying to take off the wrong thing
Old Sep 14, 2007 | 06:10 PM
Nvm guys i found out how to fix it but thanks for the responses
Old May 25, 2008 | 02:46 PM
mven3k's Avatar
How did you get them off? Just pull? or did you need the hex?
I am getting new pads and rotors and I am not sure about the rotors....
Old Jun 16, 2008 | 08:31 AM
Hen5000's Avatar
I need some help on this as well. I removed the caliper fine, and i tried screwing in the 8 mm bolts to pop out the rotors but it didn't work. Instead i popped some spring cup holder somewhere behind the rotor.
Old Jun 16, 2008 | 08:34 AM
cfdfireman1's Avatar
Don't touch the hex heads. Those split the calipers.
Old Jun 16, 2008 | 08:59 AM
Hen5000's Avatar
I already removed the caliper so that i could change the pads as well. So when i placed the bolts on the rotor the caliper is not attached in anyway.
Old Jun 16, 2008 | 10:08 AM
I should have said allen screws not hex heads.
Old Jun 16, 2008 | 11:32 AM
Hen5000's Avatar
ah ok haha. Yeah i didn't touch any allen screws.
Old Jul 5, 2008 | 02:07 PM
DirectorSe7en's Avatar
lol131233
Apr 6, 2014 08:43 AM
foxbat
Jan 4, 2014 01:24 PM
ishotphish
Mar 31, 2013 12:12 PM
aaronk
17
Oct 18, 2011 07:10 PM
