How to fix loosen stock MR gauges??
Old Oct 16, 2007 | 02:38 PM
XIRMOVE's Avatar
My stock voltage gauge came loose & is vibrating, how to fix? Superglue?
Old Oct 16, 2007 | 03:00 PM
gabeamaro's Avatar
remove it and tighten the brackets that hold it together
Old Oct 16, 2007 | 03:05 PM
Psquared's Avatar
I'm assuming yours are mounted in the bottom stock location?
--If they are, there are 2 small screws going straight UP into the dash. They're small. Remove both of those. That plastic piece will come off. Remove the gauge panel, 4 screws I believe. There are small black plastic spacers that are gonna fall out if youre not careful. No big deal, just letting you know they are there. When you pull the panel out, you'll see the brackets securing the gauges from the back. Tighten the 2 nuts on the bracket, replace everything that you took apart.....save the superglue for some funny pranks....hope that helps.
Old Oct 16, 2007 | 03:25 PM
XIRMOVE's Avatar
Yeah, the gauges are in their original location, on the bottom. Thanks guys!
myra13
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jan 16, 2017 07:26 PM
Dawood Dy
Apr 14, 2016 05:32 PM
EvoJimmy
Jun 2, 2015 09:04 PM
livevil
AEM EMS
Jun 30, 2010 04:04 AM
J8dailo
May 14, 2006 06:25 PM
