need help exhaust manifold will not come off
Old Nov 25, 2007 | 01:33 AM
TREVORSEVOVIII's Avatar
i am replacing my viii turbo with a ix and i have everything completley unhooked tubo and o2 are just sittin there unbolted. I have all the bolts off the manifold and it wont come off for anything, it is completley apart from the turbo, its just stuck on the top studs. i have pulled it , wiggled it, nothing works. my car is an o3 so its been on there for five years. does anyone know what i can do to get it off, i really need an idea/ thanks alot guys
Old Nov 25, 2007 | 08:01 PM
gabeamaro's Avatar
get a pry bar and pry the *****
Old Nov 25, 2007 | 08:08 PM
Dapper Dan's Avatar
+1
Old Nov 25, 2007 | 08:51 PM
mitdrx's Avatar
A pry bar, liquid wrench, and a rubber mallet
Old Nov 25, 2007 | 10:24 PM
Boost3dxEvO's Avatar
spray some PB Blaster all over the bolts and pry that b*tch off!!!
Old Nov 25, 2007 | 10:28 PM
AF-Evo8's Avatar
make sure you got the 1 bolt between the o2 and the block
Old Nov 25, 2007 | 11:07 PM
RevMoto's Avatar
So the turbo has been removed from the car but the manifold is stuck on the head or you cant remove the manifold and the turbo is still below it? I have never seen a stuck manifold since the gasket will never bind to the head.
Old Nov 25, 2007 | 11:13 PM
whoang40's Avatar
does the manifold even move? If it doesn't move make sure you got all the nuts off the studs. It's a pain in the a** to wiggle that thing out with the turbo in. I got mine off with the turbo still in place, I had to use my breaker bar and pry it against the block. Make sure you sold the nuts with pb blaster, it helps, good luck!
Pin2Win
29
Jan 22, 2021 05:06 PM
JC evo1
19
Sep 25, 2019 02:23 PM
MitsuJoe
468
Feb 20, 2016 11:17 AM
Pal215
Oct 29, 2015 04:32 PM
MitsuJoe
Aug 1, 2004 01:59 PM
