I torqued my DP with 37 ftlbs of FAIL.
The torch, oh man, works wonders. I heated the o2 housing near the sensor, popped on a 22mm wrench (wouldnt fit my sensor-tool) and it came right out like butter as advertised! Thanks Camaro. Now I have another issue, getting off the lower heat shield, its unbolted, cant navigate it out of the engine bay. Dont feel like removing the radiator and all that mess. Might just cut it out. any ideas?
what are your options for removal(not quite familiar with the evo's engine bay)?
Is there a splash shield you can remove or a lower bar? Or can you just unbolt the radiator from its mounts without actually unhooking the radiator, and shimmy it around until the heat shield comes out?
there will be a way cause i know mitsu engineers and designers cant be that dumb
I would have to remove the radiator, which I dont feel like doing really. I might just cut the thing off. ETS told me over the phone, that it;s really not needed.
oh yeah, no bars. The shield kinda cradles the o2/hotsection, snags the wastegate actuator.
Ended up removing the radiator, thats going to make the o2 housing alot easier, last time I did it with the radiator in.! still working, taking pics. Ill do a how-to when Im done.
Update:
Missed the SouthEast Evo/Dsm meet
Anyway, changed my o2 housing, took alot of pictures, I will post them when I get a change to do a write-up. Now everything is good, except it appears the top threaded-hole on my Cat-DP connection is stripped......Its one thing after another I swear. Im going to slide a smaller dia. bolt in and use a nut. Then I need to fill the radiator and give her a start. Oh and install my LICP. What a fun weekend.....
