location of oil pressure sensor?
Old Feb 27, 2008 | 09:03 PM
evozakk's Avatar
Originally Posted by turboDan
Yes,under intake closer to the transmission in a PITA place but the 8's don't have the problem of flickering oil lights...
8's arent exempt from it, I have an 8 and mine is flickering. The diagram shown is from the 8 manual because that is what I used to locate mine. Changed it and the light has stopped.
Old Feb 28, 2008 | 07:32 AM
I-Dom-In-8's Avatar
Originally Posted by DoughtCom
Hey TurboDan do they have a copy of the Evo IX service manual on that site? thanks
I have it...Pm sent..
Old Mar 12, 2008 | 04:44 PM
JRB_EVO's Avatar
Does anyone know the part number of the oil pressure switch for a IX?
Thanks for the help
Old Mar 12, 2008 | 04:53 PM
cush87's Avatar
If you take it to the dealer they should change it under warranty. I just got mine changed out yesterday at my local dealer, no questions asked; and my evo is modded.
Old Mar 12, 2008 | 04:56 PM
JRB_EVO's Avatar
Thanks, will order it and see what I can do.
I was so worried, this makes me feel a bit better.
Old Mar 31, 2008 | 06:55 AM
CGroovy2k2's Avatar
I've been having the same problem with my 8. the light flickers only at idle when the car is warmed up. Seeing these posts makes me feel better about it being the sensor. symptoms are just like yours.
Old Mar 31, 2008 | 07:02 AM
AznEvoIX's Avatar
I want pics.
Old Mar 31, 2008 | 07:05 AM
CGroovy2k2's Avatar
Does anyone have the EVO8 Manual...electronic... that I can have?
Old Mar 31, 2008 | 09:36 PM
justboosted02's Avatar
would it be possible to relocate the sensor on an 8 to where it is on a 9 and just plug the hole in the back of the block with a bolt?
Old Apr 12, 2008 | 04:34 PM
evozakk's Avatar
Originally Posted by AznEvoIX
I want pics.
This of course is what the sensor looks like..
This is the best pic I could get with it in the motor.. Its about 4 to 5 inches under the intake manifold.. Very easy to feel for...
And a random one.. I couldnt find my deep well so I unscrewed the spade plug.. if you have a deep well you dont have to..
Hope that helps a little..
Old Nov 14, 2011 | 03:44 AM
getgoals7's Avatar
I don't usually post very often because I normally find all my info using the search option but I can't seem to find the oil pressure sensor on my evo 8 I want to replace it. Please show me where it is. I could not find it yesterday while I was changing my oil.
Old Nov 14, 2011 | 02:26 PM
MSP608's Avatar
It's on the back of the block. Look at the diagram ak47po posted.
Old Nov 19, 2011 | 12:59 PM
getgoals7's Avatar
How do I access the sensor thru the bottom or the top of the engine and do I have to remove anything else to see it.
Old Nov 19, 2011 | 01:20 PM
todd6027's Avatar
on a 9 its in the back of oil filter housing take off right hand front wheel you should be able access it
on a 8 its at the back of the block left hand side below the steel water pipe that runs along the back of the block so not as easy
Old Nov 20, 2011 | 12:55 AM
getgoals7's Avatar
Thanks yeah I know the general location of the sensor but I just can't see it and yes I have a evo 8 but what's the easiest way to see the damn thing thru the passenger side on top of the car? Thanks for the info guys I'll give it a try tomorrow.
