evo 9 turbo install into evo 8
Old Jun 12, 2008 | 02:30 AM
speedfreak0920's Avatar
I have a 2004 evo 8 with the little 9.8 hs and am going to swap out to a evo 9 16g with the 10.5hs. Is everything straight forward? What/how will i need to modify the new turbo to fit LICP ? I know they sell install kits but i'm on a tight budget and would like to know how you guys get it done? thnx in advance for everyones help
Old Jun 12, 2008 | 03:28 AM
05WhiteEVO8's Avatar
Everything is straight forward, if you don't have the j-pipe you will need it. The lines (oil/water) can be bent to fit, I personally recommend the install kit as it will make everything that much easier. Good Luck.
Old Jul 17, 2010 | 08:46 AM
DontStopMe's Avatar
http://www.youtube.com/watch?v=svTpoHj54fY
https://www.evolutionm.net/forums/ev...s-9-turbo.html
Old Jul 24, 2010 | 10:47 PM
bayrider's Avatar
^Nice vid!
Old Aug 1, 2010 | 04:03 AM
costo23's Avatar
got to do this soon, nice one
Old Aug 1, 2010 | 04:14 AM
costo23's Avatar
Also would it be best to remove the radiator and also drop the front pipe?????
Old Aug 1, 2010 | 05:13 AM
Psquared's Avatar
You don't "have" to remove the radiator, but it makes life easier, and will reduce the chances of you damaging it. You can put cardboard over it, but still, the amount of room to work stinks. You really may want to buy the install kit. If you start re-using gaskets, you're asking for a problem. At the very least, the turbo outlet pipe is needed (j-pipe). You could bend the metal oil lines/coolant lines..but why take the chance? Here's an install kit for $139.
http://www.turbochargers.com/store/p...roducts_id/402
Old Aug 5, 2010 | 09:07 AM
TJSAP00's Avatar
Great video! Thats what I rock on my 8. The 9 turbo!
Old Aug 6, 2010 | 02:13 AM
costo23's Avatar
Yeah was planning on getting the kit to do the install. Have changed the turbos out of my RB26 with was an effort, dont think it could be any less room then that.
Thanks
Old Aug 12, 2010 | 07:39 PM
erald01's Avatar
i say sent that sucka out to fp and have them turn it into a red or black, its not really that worthy doing the swap from a 8 to a 9.
Old Aug 16, 2010 | 08:55 AM
evonky's Avatar
how much does it cost to make it an fp red or black??
Old Nov 18, 2010 | 10:18 PM
AdamWest's Avatar
to make it a red its $999 and the black is $1099 which i guess is a pretty good deal if you have a 9 turbo
Old Nov 18, 2010 | 10:23 PM
AdamWest's Avatar
Thanks
i know how ya feel man.. just did a RB25 swap into my buddys 240 only to find that he blew the stock turbo after only a month.. haa and id say it was tight
Darkn3s
Feb 20, 2012 12:06 PM
Gary 805
Jan 8, 2011 07:01 AM
scarface2jz
26
May 25, 2010 11:33 PM
getsideways
512
Mar 27, 2010 07:46 PM
rcheung
18
Oct 14, 2006 10:57 PM
