Do I have everything to install a FPGreen on a evo8?
Old Aug 7, 2008 | 10:47 AM
krillin's Avatar
Do I have everything to install a FPGreen on an evo8?
hi. i'm going to be installing a fpgreen and this is what i have pictured here (evo9 turbo in the pic)
ok, i got this list of parts from a thread:
1 - 1515A057 Fitting, Air Output
1 - MR281085 Gasket, Air Output
1 - 1310A171 Pipe, Water Return
1 - 1310A248 Pipe, Water Feed
1 - 1225A042 Tube, Oil Feed
2 - MF660063 crush washer
2 - MF660064 crush washer
4 - MF660065 crush washer
1 - MR258477 oil return gasket at bottom of turbo
it looks like i only need:
is this all i need?? i am curious about the oil return gasket. aren't there two gaskets for the oil feed line? i see one gasket listed but not the other one?? all help would be appreciated. i need to order these ASAP.
thanks everyone!!
Old Aug 7, 2008 | 10:48 AM
krillin's Avatar
also, i'm installing an aftermarket o2housing. it didn't come with any hardware. do i need to purchase anything additional for this? thanks again!
Old Aug 7, 2008 | 11:05 AM
Dr.Sound's Avatar
which o2 housing did you get?
Old Aug 7, 2008 | 01:07 PM
krillin's Avatar
ebay o2 housing, but the cleaner version.
Old Aug 13, 2008 | 01:00 PM
dan628's Avatar
They make a install kit for that, its on FP's website, I think it comes with everything you need.
Old Aug 24, 2008 | 07:56 AM
bao's Avatar
bao
you need 2 gaskets to use with the oil return pipe(turbo and oil pan side).you can bend the lines to fit evo 8. you can buy bolts at your local auto parts. make sure it's grade 5 or higher. you also need to put anti seize on the bolts.
Old Feb 13, 2012 | 01:26 PM
DragEvo9's Avatar
I tried searching but are those other stainless steel lines force performance sells necessary?
Old Feb 13, 2012 | 02:02 PM
Ian0611's Avatar
You need an Evo 9 turbo outlet pipe or J-pipe. PM me if you still need one. I've got one for sale that's in good condition.
Old Feb 13, 2012 | 03:49 PM
AWDBus's Avatar
I got one of these when I put my evo 9 turbo on my 8. Works great and way less then anybody else. Its been on there for over a year and a half now.
http://www.ebay.com/itm/Turbo-Oil-Wa...item23191d28ab
Last edited by AWDBus; Feb 13, 2012 at 03:49 PM. Reason: it helps to put the link in...
Old Jan 26, 2013 | 02:40 PM
Bignel00's Avatar
Heyy Can we get a status update on this? I recently bought a old school fp green turbo and i would like to know if buying this ebay kit is worth it. FP wants 350 for the install kit which is alittle to much for me.
Old Feb 7, 2013 | 07:58 PM
BDecker9's Avatar
You don't need the FP Gen 2 install kit. I have an old school FP Green on mine. If you buy just a regular Evo IX turbo oil/water line kit, it will work. The only difference between the IX kit and the FP kit is the braided oil supply line with an in-line oil filter. Make sure you run a IX inlet pipe also.
blonde
Jul 9, 2025 05:28 AM
EricJ@AMS
185
Jan 2, 2021 08:05 PM
w8less1der
44
Feb 1, 2018 05:37 PM
05EV08
11
May 18, 2016 09:16 AM
onyx1121
Mar 15, 2010 11:26 AM
