Where are the front JACK points on my EVO VIII
Old Nov 1, 2016 | 08:58 PM
Thoe99's Avatar
I'm about to put mine on 4 jack stands. Right now, it's got 4 jack stands and 4 hydraulic jacks. Here's how it's looking:
Is this jack stand point correct on the rear frame?
Old Nov 2, 2016 | 07:00 AM
heel2toe's Avatar
4 jacks and 4 stands? Whatup with that?
I don't like the way you have those orange jack stands positioned. The way you have them they can slip off very easily. Rotate them 90 degrees so that point sits in that lip and wont go anywhere.
As far as the correct points to have the stands you can use that area if you'd like. Personally I always positioned the jack stands on the 4 pinch welds.
Just dont jack up by the pinch weld unless you have the correct adapter to accommodate lifting by those or else it'll distort them. My preference is the front jack point under the front lower engine mount set stands under the front pinch welds lower the car down and then go to the rear and lift by the rear diff position the stands under the rear pinch welds and lower it down and you should be good to go.
Old Nov 3, 2016 | 05:08 AM
jpete709's Avatar
Give it a good shake before you go under the car. safty first.
ps. Lifts make our life so much easier.
Old Nov 4, 2016 | 05:37 PM
Thoe99's Avatar
Thanks, I repositioned the rear jack stands. I would hate my tombstone to say "death by Evo squash" (hence the multiple backups)
I did look into lifts at one point, and the only one that I really like is this floor lift made by Quickjack. It's mobile, doesn't require a high ceiling, looks stable, doesn't block the middle of the car, and can be stored against a wall.
https://www.quickjack.com/explore/quickjack-photos.html
jb988
Lancer Engine Tech
55
Jan 6, 2017 10:52 AM
aquaMan219
Dec 18, 2016 05:28 PM
kickerofdoom
Lancer Engine Tech
Sep 23, 2016 03:10 PM
ant_turbo
Jul 20, 2016 05:34 PM
xxst1tch3sxx
May 19, 2016 06:23 AM
