Things That Will Cause A Trans To Shift Poorly
Old Sep 14, 2009 | 06:01 AM
MR. EVO MR's Avatar
Got this from Team Rip-
THINGS THAT WILL CAUSE A TRANSMISSION TO SHIFT POORLY
AIR BUBBLES IN HYDRAULIC SYSTEM: BLEED CLUTCH CLICK HERE FOR MORE INFO
BENT OR WARPED CLUTCH DISC: WHEN INSTALLING THE TRANSMISSION DO NOT LET IT HANG BY THE INPUT SHAFT.
TRANSMISSION NOT BOLTED FLUSH TO THE ENGINE: MAKE SURE ALL BOLTS ARE IN PLACE & TIGHT.
MISSING ALIGNMENT DOWELS BETWEEN & TRANSMISSION: MAKE SURE BOTH DOWELS ARE IN PLACE.
WARPED OR DAMAGED PRESSURE PLATE: INSPECT WITH STRAIGHT EDGE TO MAKE SURE IT'S FLAT AND NOT SOUP BOWL SHAPED.
WARPED OR IMPROPERLY MACHINED FLYWHEEL: MAKE SURE FLYWHEEL IS MACHINED TO RECOMMENDED HEIGHT AND THAT THE MACHINE SHOP TRUE THEIR CUTTERS BEFORE MACHINING A STEPPED FLYWHEEL. STEPPED FLYWHEELS REQUIRE THE LEAD EDGE OF THE CUTTING STONES TO BE SQUARE. ALWAYS REQUEST THE MACHINE SHOP TO TRUE THEIR CUTTERS AND CUT THE FLYWHEEL TO THE RECOMMENDED OFFSET. CLICK HERE FOR MORE INFO
WORN OUT CLUTCH FORK: CLICK HERE FOR MORE INFO
PIVOT BALL NOT SHIMMED PROPERLY: DSM's MAY REQUIRE SHIMMING OF THE PIVOT BALL TO CORRECT CLUTCH FORK GEOMETRY. CLICK HERE FOR MORE INFO
AIR IN THE HYDRAULIC SYSTEM: BLEED CLUTCH.
WE RECOMMEND THE REPLACING THE CLUTCH LINE WITH THE AFTERMARKET VERSION.
IMPROPERLY OR WORN CLUTCH PEDAL ASSEMBLY: INSPECT AND ADJUST PEDAL TO CORRECT POSITION.
MISMATCHED CLUTCH COMPONENTS: USE A WELL KNOWN CLUTCH THAT HAS PROVEN ITSELF WORTHY.
IMPROPER OIL: FILL TRANSMISSION WITH RECOMMENDED OIL.
WORN SHIFTER CABLE BUSHINGS: REPLACE WORN OR DAMAGED BUSHINGS....POLYURETHANE BUSHINGS ARE RECOMMENDED.
IMPROPER SHIFTER CABLE ADJUSTMENT: ADJUST SHIFTER CABLES.
MISMATCHED SHIFTER BASE, CABLES OR SHIFTER LEVERS ON TRANSMISSION
Old Sep 23, 2009 | 03:21 AM
MR. EVO MR's Avatar
people here are asking the same questions
Old Sep 30, 2009 | 01:07 AM
1SloEvoNoob's Avatar
if only it was not in all caps i would enjoyed it
Old Oct 7, 2009 | 02:13 PM
e2lancer's Avatar
Will check, does this also make a difference if the gears shift fine while car isn't running...
Stationary stage is fine, only when car has started - any ideas : anyone...
Old Oct 7, 2009 | 02:18 PM
EVOlute GSR's Avatar
Those are really great points. Need to look into a couple, as I myself am experiencing minor issues...
Old Oct 31, 2009 | 02:11 AM
klever's Avatar
Thank you for the good ponts..
six40
Evo X Dyno Results
11
Dec 21, 2017 11:50 AM
LOWPROaero
41
May 20, 2013 12:01 PM
AC80
Feb 28, 2012 07:23 PM
avengerhed
For Sale - Cars For Sale
Sep 10, 2005 10:33 AM
Kaane
Jun 1, 2005 02:58 PM
