Help!!! Can't narrow down a random engine misfire on my evo!
Old Apr 8, 2010 | 12:10 PM
EVIL 9 g00n's Avatar
Question Help!!! Can't narrow down a random engine misfire on my evo!
i just got a new heavily modified evo 9 and when i inspected it evreything thing was good except that sometimes when i turn it on it will idle up and down strangely to the point where it's about turn off and sometimes it does turn off at a full stop. i took it to get scaned and the code that came up was a multiple random engine misfire (po300). so i checked it again to see if it was a bad spark plug or anything else and it seemed fine. a buddy of mine was guessing that it's probably a bad sensor. does anyone have any idea of what it could possibly be?
Old May 12, 2010 | 04:22 AM
gqcode's Avatar
Veteran: Air Force
The computer can also normally identify the specific cylinder in which the misfire has occurred. A misfire is nothing more than a lack of combustion, which can be caused by poor fuel quality or metering, low compression, lack of spark or unmetered air entering the engine. OR see a tuner he should be ables to reach your ecu
Old May 15, 2010 | 01:55 PM
schroeder02's Avatar
Check your CKP/CMP with a DMM, make sure they both are working properly.
Old Nov 16, 2010 | 10:33 PM
VETDRMS's Avatar
Good advice above. Once the misfire is detected it will shut down injectors on the pair of cylinders, that's why it runs like crap. Bad plug wires can cause intermittent misfires as well.
slowonder
Feb 26, 2017 01:58 PM
maknuge
AEM EMS
10
Feb 8, 2017 09:39 PM
maknuge
Nov 18, 2015 12:04 PM
treager
Aug 27, 2014 11:28 PM
bboy_RES
10
Mar 15, 2009 08:17 PM
