How To: Wheel Stud Removal/Install
Old May 23, 2010 | 10:08 PM
o-townFLA's Avatar
Lightbulb How To: Wheel Stud Removal/Install
The main reason for this upgrade would be either to remove a broken or stripped wheel stud or to upgrade your wheel studs to extended studs to run spacers.
Their are several ways to due this but I went the shorter route, via "dont stop, hammer time"...
So out with the old and in with the new...
Parts to be installed are ARP extended wheel studs. Model #400-7717
and some featherlight RobiSpec lug nuts. Sized 12x1.5
The miscellaneous tools required are pictured below.
I jacked my car up using the pinch weld and then placed a jack stand in the alternate jack point.
Now zip off your wheel
Old set up...
Now remove your Caliper and hang it up which either way your like...
ghetto fabulous
heres a HOW-TO on front rotor/caliper removal ---> https://www.evolutionm.net/forums/ev...nt-rotors.html
Caliper bolts to be removed
Once the caliper and rotor are removed you can now get to work. Pay particular attention in the orientation of the spindle. You must have it this way for the studs to be removed.
With both wheels elevated it is relatively easy to remove one stud and then spin the spindle for the next stud.
With all the studs removed you can now place the new ones in.
I placed spacers that were a larger inner diameter than the studs and a M12 nut/lug to pull the new stud in. As you can see I used some lubricant to ease the operation
NOTE: I did not use a jack stand on the non-working side. Reason being is that the spindle will continuously spin when trying to tighten/pull the studs in if both wheels are elevated. What I first would do is knock out all the old studs with both wheels elevated. Once the old studs were all removed and the new studs installed, I would lower the non-working side just enough for the tire to give traction. I would then tighten/pull the stud in.
New set up w/ anti-seize on the threads
Old May 23, 2010 | 10:22 PM
wrecklezz1's Avatar
nice write up
Old May 24, 2010 | 04:34 AM
squid267's Avatar
nice write up
Old May 24, 2010 | 04:35 PM
craighead's Avatar
good sheet
Old May 24, 2010 | 07:15 PM
mullski's Avatar
good write up i was just searching for a diy on this
Old May 26, 2010 | 10:48 AM
pennies_hatchie's Avatar
Awesome setup. I was thinking of doing this since I was planning on getting some 18x9.5 +22 rims and spacers. Great job and thanks for the help.
Old Feb 13, 2011 | 06:31 AM
cij911's Avatar
Sorry but I searched for the 400-7717 and could not find (was wondering if a stronger bolt)....Was that a typo and is the real part # 100 - 7717 ? Thanks !
Old Mar 6, 2011 | 11:06 AM
analogEvo's Avatar
Need to do this aswell . Seems not to bad
Old Mar 8, 2011 | 01:05 PM
aggieEVO's Avatar
Nice write-up, but any thoughts on the hammering damaging the wheel bearing? Just curious.
Old Mar 9, 2011 | 09:05 AM
SlickEvoIX's Avatar
very well written post. thanks a lot...wheel studs are a pain...town fair tire snapped two of mine last time i was there and didn't tell me!
Old Nov 6, 2012 | 05:24 PM
andpic's Avatar
Subd.
Thx!
Old Nov 7, 2012 | 10:49 AM
dastpe's Avatar
How long did this take you?
Old Nov 15, 2012 | 09:33 AM
teamrevjohn's Avatar
Good write up! the rear ones are PITA, but doable
Old Nov 15, 2012 | 01:13 PM
shaggy4267's Avatar
Fronts are cake.
Its the rears that I still have yet to do...
Is there any tricks to doing them?
Old Nov 25, 2012 | 09:53 AM
smoOVE's Avatar
^^ yes, what about the rear studs?
