Need help cleaning marks on paint.
Old Mar 25, 2011 | 10:50 AM
wickedevos's Avatar
So i just bought an evo. There is white marks on the rear trunk which dosent go off after washing my car. Any suggestions, or any product which is good??
Attached Thumbnails Need help cleaning marks on paint.-img_20110321_140800.jpg
Old Mar 25, 2011 | 11:01 AM
Default_User's Avatar
have you tried some claybar?
Old Mar 25, 2011 | 03:44 PM
wickedevos's Avatar
nope didnt try it before. Any brand?
Old Mar 26, 2011 | 07:04 AM
EVO KNVL's Avatar
How big or thick are the marks? Clay bars work great on finer contaminants but on thicker stuff, I'm not sure it would. When that's the case, I usually use a steam cleaner (the type for your clothes) and soften it up a bit and peel it off.
Old Mar 26, 2011 | 07:38 AM
LGshow19's Avatar
What about "Tree Sap" marks?
Old Mar 26, 2011 | 07:49 AM
mifesto's Avatar
also you can bring it to any pro detailer. he'll tell you in a few seconds if he can remove it with remove the marks and make it "like new"
Old Mar 26, 2011 | 03:41 PM
jplgsx's Avatar
A good auto parts supply will have a quality clay bar kit. Use as instructedand no need to rub had, let the clay do the work.
Old Mar 27, 2011 | 10:25 AM
Aspen One's Avatar
Clay bar is good for finer things...I have always used 3M detail products thats what most detailers use..
Old Mar 27, 2011 | 09:29 PM
wickedevos's Avatar
I will try clay bar and let you guys know the update. Thanks guys for your help
Old Mar 27, 2011 | 11:45 PM
umopp's Avatar
If the clay bar doesn't work, try some rubbing compound. They have a mild abrasive that can take off stuff like that.
Old Mar 29, 2011 | 03:46 PM
wickedevos's Avatar
Tried rubbing compound and buffed it with machine. Didn't work...will try clay bars now...
Old Mar 29, 2011 | 05:19 PM
EVO KNVL's Avatar
I'm telling you, try that steamer I mentioned earlier. Cost about $25 at Walmart/Target. Works great. I original purchased it to remove my tints before I got re-tinted again. Works like a charm.
Old Mar 29, 2011 | 05:46 PM
awdordie's Avatar
Clay bars will almost take stds off the hooker. Standing on the corner so be careful using them if u have a good brand. I used a carbrite clay bar to get off little rust spots on the rear aka" rail dust" from the brake pads and it started to take the paint off as well.
Old Apr 9, 2011 | 09:55 AM
dastallion951's Avatar
i use the mothers claybar kit, do it in a shaded area, so excessive spray from the applicator for the claybar kit doesnt dry before you get a chance to use it, if your gonna use rubbing compound use it after washing but before you clay bar it. The rubbing compound will do a better job of removin foreign material on your paint, then itll be a bit rough after the compound, then go over it with clay bar to make it smooth like a strippers butt...haha, then after you claybar go over it with a good wax kit like mothers...then you should be good to go.
Old Apr 9, 2011 | 10:35 PM
wickedevos's Avatar
thats some nice explanation dastallion951. Actually i dont really get time to do it since m busy with work and skool. But gonna do it soon and let u know if it worked or not..
