So you sandblasted your valve cover and now its trashed...wait! Theres a solution!
Old Aug 17, 2011 | 08:32 PM
andred's Avatar
very detailed. also good idea with safety wires
Old Aug 22, 2011 | 05:52 PM
rong.'s Avatar
Looks perfect, and nice write up. I will most definately use this!
Old Jan 12, 2012 | 12:16 PM
Lukelis's Avatar
do the same
Old Feb 21, 2012 | 12:22 AM
artinist's Avatar
ok so whats the alternative to getting it prepped before powdercoating the valvecover?
just hit it with paint remover and use sandpaper to clean the minor leftovers?
Old Feb 21, 2012 | 12:28 AM
EvoFredo's Avatar
Thats a good question. I wonder what TCC does to help prevent any of this? just mentioning them because its the main company i see that does evo valvecovers on this forum. But im pretty sure a blast must be done so that the powder will have a good surface to Bite onto.
Old Feb 21, 2012 | 12:44 AM
06redrocket's Avatar
My powdercoater just covered up the baffles during sand blasting and I havnt had a single problem.
Old Feb 21, 2012 | 02:07 AM
SaulHudson's Avatar
This is a really good write up. One question though, why tap for bolts and go through the trouble of safety wire when you could just put some blind rivets back in? Like Huck or cherry max. I realize a huck or cherrymax gun isn't an item you can go buy at home depot, but If you take this to an aviation shop that can shoot either of these they can shoot those (what is it 16?) in 10 mins.
Old Feb 22, 2012 | 07:05 PM
lghtngyello03's Avatar
Same, but my powdercoater just asked for an old valve cover gasket and taped up the the whole underside of the valve cover and then taped the PCV hole, along with the spark plug tube holes.
Old Feb 22, 2012 | 08:39 PM
n2oiroc's Avatar
nice thread! im about to do this, but im going to dull the tap slightly and just slightly crimp the threads of the bolts in a vice and loctite instead of safety wire. the bolts cant back out with distorted slightly cross threaded threads.
Old Feb 22, 2012 | 08:55 PM
420a-t's Avatar
If they tape it up, it doesn't mean all the media was blocked 100%. Have you seen the different kinds of media used for sandblasting? You could probably stop 99% of it, but its really hard to keep all of it out. And if the stuff does get under your baffles, there is no way in hella you can clean it all out wihout removing the baffles. I've coated vc's before and I also did the same thing the OP did, but I didn't use safety wire, I just used loctite.
I tapped mine because I figured that I could take them out again if/when I want to change colors. Simplicity!
Old Mar 1, 2012 | 07:48 PM
EvoDom's Avatar
Plain and simple. If you glass bead/sand blast your valve cover you MUST pull the baffles out and clean everything. I just did it on mine and I rivited the baffles back in.
Old May 12, 2012 | 02:22 PM
EVOkeeper's Avatar
your lockwire is installed wrong. the idea is perfect, but the result is wrong, i see many of those installed in the loosening direction. technically it could only loosen so much anyways but at the end of the day its done wrong.
Old May 13, 2012 | 02:20 AM
2006GSR's Avatar
Digging how your waste gauge dump tube is done
Old Oct 4, 2012 | 10:36 AM
MTL-Evolution's Avatar
Good Job!
Old Oct 5, 2012 | 07:43 AM
jay777's Avatar
When I had my EVO I valve cover coated, I removed the stock baffle before sending it to my powder coaters so there was no risk of getting any media under it.
When I got the cover back, I ordered a replacement baffle from 'greengoblin' on DSMTuners.
http://www.dsmtuners.com/classifieds...baffles-43860/
Maybe if we can get enough interest, he would make some for the EVO 8/9 cover?
The quality of the piece was excellent, and fit perfectly!
Group buy??
