how to change disc rotars off an evo 8
Old Aug 12, 2011 | 09:56 PM
evo8mr2004's Avatar
Can any tell me how to change the disc rotars off an evo8mr?
Thanks in advance!
Old Aug 12, 2011 | 10:00 PM
seqenretao's Avatar
remove wheel....remove the two bolts holding the brake caliper hang aside as the brake line is still connected then pull the rotor off....Im sure there are some how twos with pictures if you really need it but changing disc brakes is the same on any car.
Old Aug 14, 2011 | 04:16 AM
marcusE's Avatar
who owns and evo and doesnt know how to remove a brake rotor. wow.
Old Aug 14, 2011 | 04:37 AM
hempele28's Avatar
lighten up on the guy. He is making an effort to learn. Also if you are going to flame people make sure you spell things right. It's "an", not "and." To the original poster you may also have to bang the old rotors a little bit with a hammer to break them free. Overall though it is very easy to do.
Old Aug 14, 2011 | 05:54 AM
jr_2006IXMR's Avatar
couldn't be clearer than that.
Old Aug 14, 2011 | 08:52 PM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
the rotor gets stuck sometimes so what u will see is two holes on the hat that have threads, just remove one of the screws that bolt down the radiator brackets to the frame and screw it into the threaded hole in the rotor and it will pop it off.
Old Aug 15, 2011 | 08:15 AM
deeman101's Avatar
Lmao. Love that info! I usually use a combination of kicking, WD40 and violently shaking (using jackstands) to get it off.
Old Sep 26, 2012 | 04:39 PM
antman_21's Avatar
What about the rear rotors
Old Sep 26, 2012 | 05:41 PM
deylag's Avatar
Here is a thread to help you. Even though its the Evo-X its the same procedure.
https://www.evolutionm.net/forums/ev...placement.html
Old Sep 26, 2012 | 06:04 PM
596736's Avatar
Dang I did not know this. One time one of my front rotors was so stuck I had to use pb blaster to get it off. Nothing worked aside from that.
Old Sep 27, 2012 | 06:08 AM
Davo's Avatar
when reinstalling the rotors, sand the back where it touches the hub and also sand the hub and use some grease and they would always come out easily
OneCrzyEvo21
May 24, 2016 10:34 AM
KOTT
Mitsubishi TC-SST Discussion
May 20, 2012 08:30 PM
ProfessorX
Sep 5, 2011 06:17 PM
Zerokei
11
Aug 1, 2009 12:36 AM
