where to get oil sender fitting
Old Aug 20, 2011 | 12:23 AM
Jingming88's Avatar
I trying to install oil tem gauge for evo 9 , I had oil tem sender just need fitting for sender
Old Aug 20, 2011 | 06:34 AM
Jingming88's Avatar
Bump
Old Aug 20, 2011 | 06:46 AM
DarkEvoIX's Avatar
I got my bushings from 42 Draft Designs. They adapt the 1/8" sender threads to the Evo oil filter mount.
Old Aug 21, 2011 | 05:31 AM
Jingming88's Avatar
Thanks man! But what store is it ? By the way how is your evo running
Old Aug 21, 2011 | 06:25 AM
Jingming88's Avatar
I found it man but can it be replaced oil drain plug?
Old Aug 21, 2011 | 11:13 PM
VROOOM's Avatar
You're meant to put it on one of the blanks on the oil filter housing. It's a hex nut above the oil filter.
Old Aug 22, 2011 | 05:08 AM
Jingming88's Avatar
Is that the only place to put it on?
Old Aug 22, 2011 | 07:03 AM
VROOOM's Avatar
Or you could use a sandwich plate. There's two hex blanks on the oil filter housing, for oil temp and pressure gauges. You can use either one.
jeffbum
Dec 3, 2007 11:45 AM
ralliart67
Mar 7, 2007 04:07 PM
aboh6leenz
Feb 16, 2006 10:22 PM
mitch44759
Aug 8, 2005 06:46 AM
CombatCQB
Oct 28, 2003 05:17 PM
