Oil temp and pressure gauge install?
Old Feb 12, 2006 | 12:26 PM
aboh6leenz's Avatar
I have read the how-to's and am still confused on what fitting/adapter I am suppose to get. I am talking about the ones you would put next to your oil filter for the senders.
Here is the install: https://www.evolutionm.net/forums/sh...d.php?t=108819
Just wondering where I would get the fitting and which one is the correct one?
Old Feb 12, 2006 | 12:29 PM
Jakeg97's Avatar
for defi gauges
http://www.42draftdesigns.com/product/42902.htm
Old Feb 12, 2006 | 01:09 PM
Invoice EVO's Avatar
Veteran: Air Force
Oil temp adaptor 1/8" NPT http://www.42draftdesigns.com/product/42912.htm
Old Feb 12, 2006 | 01:36 PM
aboh6leenz's Avatar
Is that where you all got it? I dont want to order it online and have to wait for shipping if I could just go to the local hardware store and pick one up, but I heard that home depot doesnt carry them?
Old Feb 12, 2006 | 02:28 PM
Veteran: Air Force
Yep I ordered both. They just got them in stock about two weeks ago. Give them a call to find out if they have anymore in stock. Or PM 2kjettaguy and ask.
Old Feb 16, 2006 | 02:38 PM
silex's Avatar
You won't be able to get these locally since you need 3/8" BSPT to screw into the filter.
Old Feb 16, 2006 | 10:11 PM
r2kbug's Avatar
what brand gauges are you install by the way?
Old Feb 16, 2006 | 10:22 PM
JTB's Avatar
JTB
The threads are not NPT, they are BSPT.
The thread pitch is different. On a 3/8 fitting there are 28 threads per inch on BSPT versus 27 threads per inch. If you use NPT you will bugger up the threads.
I used 3/8 BSPT to 1/8 BSPP reducer for each -- oil pressure and temperature.
http://www.mcmaster.com/nav/enter.as...692&pagenum=20
One had to be drilled out slightly to allow for the oil temp sender to pass through.
Note: The difference between BSPT and BSPP is that the T in BSPT stands for Taper. The BSPP fitting does not taper but it does seal well and has the correct thread pitch.
benIX
Dec 31, 2016 09:25 AM
Exsubie22
Sep 7, 2016 09:02 AM
STM Tuned
EvoX 'For Sale' External Engine / Power
Sep 17, 2015 03:23 PM
thenatureboyjs
Lancer Aftermarket Forced Induction Tech
30
Sep 2, 2015 09:46 PM
livesports
Dec 16, 2005 05:24 PM
