Walbro 400LPH Fuel Pump Modification
Old Nov 14, 2011 | 10:54 PM
drb's Avatar
drb
Originally Posted by jdm-vr4
so any updates on the stock fpr and this pump?
Not from me. I decided to buy the Walbro 400 and an aftermarket adjustable FPR. I have not installed them yet.
Dan (drb)
Old Nov 19, 2011 | 09:32 AM
wizzo 8's Avatar
To the OP how much a difference was there between the DW and the Walbro? Im on the DW now and Im running out of fuel with E85. I did the rewire also but still not enough flow. Im thinking of going with this pump but Im not sure if Im wasting my time and money.
Old Nov 19, 2011 | 08:49 PM
krisdlm's Avatar
dont mean to hijack but im stuck btw the 400lph and dual inline pumps. I have maxed out my rc1000cc and walbro 255 on e85 and I am stuck btw going for an inline or trying out the 400lph.
Old Nov 20, 2011 | 03:59 AM
wizzo 8's Avatar
Sounds to me like you need bigger injectors and pump. I would get the 400pump 1st as this will help push your 1000 some more.In the end your most likely going to need bigger injectors. Even with throwing as much fuel at the injectors as you can.
Old Nov 20, 2011 | 06:43 AM
drb's Avatar
drb
Sounds like it's time for bigger injectors, Walbro 400 & probably an adjustable FPR. Or you could go with a double pumper and a Hobbs switch in which case you won't need the adjustable FPR.
Old Nov 21, 2011 | 09:08 AM
evoiao's Avatar
i see on ebay there are kit for this pump. will the kit let me avoid having to cut into the plastic housing.....I currently have a 255 and am about to switch to e85 in about a week.
Old Nov 21, 2011 | 09:38 AM
wizzo 8's Avatar
You need to cut the housing no matter what. Unless someone comes out with an aftermarket housing to just drop in.
Old Nov 21, 2011 | 12:06 PM
Geoff Raicer's Avatar
just cut the housing, its not that big of a deal. plan it out and do it clean
Old Nov 21, 2011 | 02:55 PM
krisdlm's Avatar
David from Buschur suggested the same thing and I think I will go that route. But when you say I'll be able to push the injectors a bit more, how much more considering they were at 95% duty cycle at 6k with the pump maxed out. My tuner also suggested Aeromotive.
Old Nov 21, 2011 | 08:23 PM
wizzo 8's Avatar
I would say it will maybe bring it down to 80-85%. You can try the aeromotive but you will most likely still run out of fuel.
Old Dec 2, 2011 | 10:05 PM
3K's Avatar
3K
Old Dec 26, 2011 | 09:27 PM
tscompusa's Avatar
im pretty sure once you rewire its gonna overrun the stock fpr. my customers installing this pump tomorrow in his evo 9 not rewired so will get some data with it not rewired and see how much power it can support on e85 with fic 1550's. he only needs around 550 since hes still on stock block.
Old Dec 28, 2011 | 11:08 PM
Thrilla's Avatar
Veteran: Army
updates?
I'm interested in the results of this. Any updates?
Old Dec 29, 2011 | 09:53 AM
Rondata.'s Avatar
X2 since I might go this route too. Thanks to the OP for the good info.
Old Dec 29, 2011 | 02:22 PM
if nobody answers this question in the next 2 weeks, ill be running stock fuel rail & fpr on my personal evo project build, walbro 400lph and id 2000cc injectors
