Wiring question on SPAL HP fan install
Old Mar 22, 2012 | 02:33 PM
supersnow's Avatar
I'm installing a 13" SPAL HP fan to replace the AC fan behind the intercooler. My question is; there are two connectors coming from the fan controller: one is clearly ground (one black cable); the other has two cables going into the connector( one black with a yellow line and the other a complete white cable). The SPAL fan has one simple ground cable and one red power cable.
How do I splice these cables?
Thanks for your help!
btw; I'm controlling both fans with the ECU and I want to keep that capability.
Old Mar 23, 2012 | 04:01 AM
supersnow's Avatar
I'm assuming yellow line cable is for the AC fan switch in cabin and the white is ecu control depending on parameters?
Thanks!
Old May 23, 2016 | 01:20 PM
ecktt's Avatar
Don't mean to dig up an old thread but did you find a solution? What fan did you use. I have to change that fan.
Old May 23, 2016 | 01:52 PM
meckert's Avatar
It will blow wired either way, need to determine which way you want air flow and wire it up that way.
Old May 25, 2016 | 02:53 PM
ecktt's Avatar
I'm thinking a relay on each wire and then join the output to function like an "or" circuit while isolating the 2 sources.
Alchem1st
Mar 15, 2022 08:47 AM
Evo_8_power
Jan 2, 2018 04:51 PM
RallySport9
Apr 13, 2017 03:06 PM
ZyBeR
AEM EMS
Jul 2, 2016 10:17 PM
doncarbone
42
May 1, 2016 09:45 AM
