Another DIY Cold Air Intake Heat Shield - With Testing
Old Sep 20, 2012 | 09:01 PM
  #31
MrSquirr3l's Avatar
my question is what did you use to make the bends?
Old Sep 21, 2012 | 05:18 AM
  #32
fantrman's Avatar
I assume you mean the bends in the aluminum sheet to form the shield? I just placed the sheet on the edge of my work bench and bent it - no big deal. Aluminum is easy to work with. No need for a sheet metal break or anything fancy.
Old Sep 22, 2012 | 03:48 PM
  #33
jholla's Avatar
nice
Old Sep 25, 2012 | 08:40 PM
  #34
FenixTX717's Avatar
I'll pay you to make me one
Old Sep 27, 2012 | 12:31 PM
  #35
YogSaahoth's Avatar
Veteran: Army
You should definitely consider ducting air from the front bumper. My bumper has the cf ducts in it and it provides two channels for routing an air supply. Out with the washer fluid sprayer and you have all the room you need. I bought all supplies needed for mine from Lowe's...
3" aluminum ducting for dryer
3" to 4" galvanized reducer (end piece)
black rubber molding for auto doors/windows (not needed but looks cleaner)
Garden section for some of the black corrugated-type tubing. It's 4" tube...non-perforated drainage tubing. Not absolutely necessary but really lent itself to finishing the look and it also hold the entire thing in place with minimal zip-tie usage.
4" hose clamp to secure outer black tube to galvanized reducer
Aluminum foil tape...in my experience holds better then duct tape
With just the above duct my cruising temp (40mph or faster) is 1-3 degrees above ambient and Right at ambient during WOT pulls (maf temp log evoscan)
In the process of making a heat shield. Really like your design. Drb has a very nice box setup also. I most likely will not do a full enclosure cus above all, I must hear the sound of that hta green winding up lol.
In response to the pre-turbo air intake temp debate...colder incoming air improves compressor efficiency. period. Still need a good IC system to take full advantage tho. Nice work everyone
Old Sep 29, 2012 | 02:07 AM
  #36
GhostAWD's Avatar
great thread........definitely on my mod list
Old Nov 9, 2012 | 09:45 AM
  #37
Mr.C2's Avatar
i dont know if anyone mention... u should make it with the stock intake scoop and see if that make anymore of a difference... i would think that it would bring in more cold air when driving?
Old Nov 9, 2012 | 12:45 PM
  #38
drb's Avatar
drb
That's what I did. There is no doubt in my mind that it helps but I have not done any testing.
Old Nov 9, 2012 | 01:30 PM
  #39
TpArK's Avatar
That is really nice drb. How did you assemble the box? Did you weld?
Kind of looks like you just left ledges on each piece to screw the box together. I would love to see more close up pics if possible.
Fantastic job
Old Nov 9, 2012 | 04:02 PM
  #40
drb's Avatar
drb
Fantastic job
I used .040” 6061-T6 aluminum sheet material, with lot’s of sanding, buffing, and polishing for the finished look. I made a couple of jigs out of wood to make the bends. I riveted some aluminum rectangle bar stock to the aluminum sheet and then I drilled & tapped the holes for the bolts that hold the cover on.
Old Nov 9, 2012 | 04:40 PM
  #41
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Holy **** dude, that is an amazing piece.
If it came in "OEM brushed aluminum" I would buy this.
Very nice work!
Old Nov 9, 2012 | 05:18 PM
  #42
whiteEvo08Y's Avatar
Very nice work!
+++1 Yes i agree. I would buy this anytime. IF you make extra ones, count me in.
Old Nov 9, 2012 | 05:34 PM
  #43
johnnydemz4G63's Avatar
+1000 this is an awsome piece! good job dude you inspired me to make one now.
Old Nov 9, 2012 | 06:49 PM
  #44
Lyzek01's Avatar
Great write up! this is definitely on my to do list
Old Nov 10, 2012 | 10:03 AM
  #45
Mr.C2's Avatar
Oh I see haha I didn't go thru the thread... Man ur work looks nice... Wish I could do something like that for my car... Good job man... I'll probably be making a one out or cardboard lol and then upgrade to metal hahaha
