How to Setup Tephramod V7
Which one would I use for the rom's BDE and Adder table :
1. - PSIa16 OMNI4barMAP
or
2. - PSIa8 OMNI4barMAP
I assume I use the below for logging boost error:
BoostErrorPsi OMNI4barMAP
Hello guys first thank you for the writing real i was lost about tephra mod in the beginning, the writing says (Download the ROM, and the XML Pack from this page) do it mean both of them has to be copy pasted in the same (default location) that or we have the ability to choose ether the hole XML Pack or our ROM ID individually?
and when you sad Open you new V7 ROM you mean we have to be connected to the ECU and read ECU than setup tephra ROM or just opening ECUflash and from there we can setup tephra mod?
thank you
thank you
The XML pack goes into the EcuFlash directory. The rom can go wherever you want, you're opening it with ecuflash. Just like when you want to open a Word document, it doesn't have to be in a certain place.
The v7 romid you will use depends on your car and what is on it right now. For example if you have 88590015 (USDM evo ix), then you'd use 88590715.
By opening you new v7 rom we just mean opening the .bin or .hex file you downloaded. It's stored on your computer after you download it; you don't need to be connected to the ECU.
one extra question do we have to also copy and paste the MUT table?
... thank you!
