rwd evo
Old Jan 29, 2013 | 12:14 AM
gtn_dwn's Avatar
rwd evo
currently building an evo 1 daily driver but have a spare parts car now that have many crazy thoughts about messing around with one of many is rwd i have looked around and have only found limited pictures and info but want to see how the mounts on the 4g63 are to spin it around north south any pictures or comments would be tons of help thanks
Old Jan 31, 2013 | 09:31 PM
Redspeed's Avatar
Buschur sell an adapter to mount rwd GM trannys. Don't know specific trans. If the spare car is fwd you'll need to build a sub-frame that will allow the engine to be mounted in a rwd configuration or fit one from a rwd car. Don't forget the drive shaft will need to be custom made.
Old Feb 3, 2013 | 01:37 AM
gtn_dwn's Avatar
i have gearbox sorted and noticed also about the new subframe required was more wondering how the engine mounts are set up since the side engine mount would technically be at the front of the engine bay now. i have been told that i could drill and tap the block to get the mounts on but unsure how true this is
Old Feb 3, 2013 | 06:56 PM
Redspeed's Avatar
Im not too sure about drilling the block. You should call Buschur about that. They used to race a mean rwd dsm.
Old Feb 3, 2013 | 09:40 PM
xXANCHORMONXx's Avatar
technically all youd have to do is seal the tcase and remove the axles, depends on what powere you were running it wont last long tho
Old Feb 4, 2013 | 02:46 AM
gtn_dwn's Avatar
looking more at turning the motor the other way around for the strength wanna be able to give it some beans without breaking it have found an easier i do believe by using the mitsi L200 ute they run a 4g63 sohc carby motor but you can bolt the dohc head onto the block as its already a north south motor and can also use the L200 gearbox and they come with a factory lsd also
Old Feb 4, 2013 | 03:59 PM
powerdriver's Avatar
You could try the Genesis subframe. Similar engines..
Old Feb 4, 2013 | 06:19 PM
gtn_dwn's Avatar
the 2010 hyundai genesis? how much work is involved in using this subframe for the 4g63?
Old Feb 9, 2013 | 05:27 PM
Redspeed's Avatar
I don't know about that. The genesis is related to the 4B11 not the 4G63.
Old Feb 16, 2013 | 07:58 AM
Teal2nnr's Avatar
I think its a lot more work then its worth to be honest.
Old Feb 24, 2013 | 05:27 PM
manss's Avatar
against it but interested to see outcome. goodluck
Old Feb 25, 2013 | 11:41 PM
gtn_dwn's Avatar
isn't the most natural thing. but will be interesting to see it going have got most of the problems sorted in theory just need to get it in action, have gone with an l200 crossmember the 4g63t has mounting points already on the side so shouldn't be a problem
Old Feb 27, 2013 | 07:47 AM
flexer's Avatar
against it but interested to see outcome. Goodluck
+1
Old Mar 5, 2013 | 02:36 PM
bnr34rb26dett's Avatar
have you looked at team orange and their setup?
Old Mar 6, 2013 | 05:54 AM
gtn_dwn's Avatar
haven't heard of team orange before but will look more into them but just from the video the motor is somewhat around the other way im using an earlier evo motor so intake is on the other side
