Battery relocation
Old Sep 15, 2013 | 04:56 PM
  #31
JaYr_EvO9's Avatar
LOoks good
Old Sep 24, 2013 | 07:37 AM
  #32
83841's Avatar
I need to do this soon, awsome write up!
Old Oct 23, 2013 | 08:17 PM
  #33
deproux's Avatar
This is a really good write up. I have very little experience with the electrical side of a car though, so I am thinking of just having a shop rock this one out for me.
Finding time these days is impossible for me right now as well
Old Dec 11, 2013 | 06:45 AM
  #34
bighead87's Avatar
I have a question I know the positive going to the batt is the main 1 going to the distribution box what are the other wires on the other side any help would be appreciated thanks also where can I get this distribution box
Old Dec 14, 2013 | 08:27 AM
  #35
rotarynemesis's Avatar
This is a great DIY. Ill be following this shortly for my car and will post up some pics when its completed.
Old Jan 17, 2014 | 04:52 PM
  #36
CNOEVO22's Avatar
i followed this worked great. i disconnected the washer fluid line on accident and didnt realize it at first. needless to say there was a little wet spot lol.
Old Jan 19, 2014 | 08:27 AM
  #37
WRCturbo's Avatar
So I am in the process of doing this RIGHT NOW!! I have a question though. Where do I run the Pos wire inside the engine bay. I may be over thinking this, but I don't want it to touch anything that could cause damage. Any chance someone who has done this can describe and or take some pictures that show where I should go?
Thanks!
Old Feb 8, 2014 | 06:46 PM
  #38
CNOEVO22's Avatar
sorry late reply i just ran it against the fir wall, behind the brake lines and all the wireS.
Old Apr 21, 2014 | 06:40 PM
  #39
DRO.Evo8's Avatar
Great write up
Old Aug 19, 2014 | 04:46 PM
  #40
evo98urv8's Avatar
Did u need to run a ground wire back to the block?
Old Aug 19, 2014 | 05:59 PM
  #41
Bignel00's Avatar
@ evo98urv no, you can ground in right inside the trunk, there is no need to ground all the way back to the block
Old Aug 19, 2014 | 06:14 PM
  #42
evo98urv8's Avatar
Thanks was just worried about a voltage drop. how about grounding the block to the chassis? 1 gauge wire should be more then big enough?
Old Apr 27, 2015 | 09:29 AM
  #43
Ghost4G63T's Avatar
Where did you buy that Stinger power distribution box ?
Old May 3, 2015 | 07:33 PM
  #44
tommyooooooh's Avatar
I know this is an old thread but I'm about to do this next weekend and had a couple ?s.
1. What do you do with the under hood ground cable that used to connect to the battery?
2. Are you guys venting your batteries? I've never payed attention to vents on a battery before. I'm assuming you can run a hose off a batterie then run the hose outside of the car?
Old May 13, 2015 | 10:00 AM
  #45
JCevo805's Avatar
great write up. ill be relocating mine soon ! 👌
