Defi Oil Psi over 140?!?!?
Old May 14, 2013 | 09:16 PM
Macurts's Avatar
Alright so i hooked my oil psi gauge and and swapped my oil temp gauge out in the same spot (is this right first of all?) Now the gauge is reading all the way to PEAK! It does the full sweep on start up, i can change the "warning" alert on it, but its sitting all the way up there and its not moving. The gauge is daisy chained by one wire to the other gauge. Its also hooked up to the "oil psi" on the actual "defi link".....i have no idea what to do now......
Old May 14, 2013 | 11:16 PM
BEKevo's Avatar
Where do you have the oil pressure line running to ? The oil filter housing or somewhere else?
Old May 15, 2013 | 06:51 AM
Macurts's Avatar
yeah its installed on the oil filter housing.....my other 2 defi gauges are working normal
Old May 15, 2013 | 07:45 PM
BEKevo's Avatar
Hrmm.. Can you post the part # to the defi gauge kit you got? I'll see if I can dig something up for you...
But for now do you see any kinks in the oil pressure line? Or any possibility of something clogging it during installation (ie Teflon tape or something)? Also what weight of oil are you running in the motor?
Old May 15, 2013 | 07:55 PM
BEKevo's Avatar
Also 100psi + is normal during start up. Depending on the weight of your motor oil, you should be seeing between 15 and 35 psi at idle, warm (engine at operating temperature). If its reading 140psi at ALL times, like at idle warmed up, something is definitely up..
Old May 15, 2013 | 08:33 PM
Silver-IXse's Avatar
lucky you i have my aem oil psi at 200 @ times usually depends whats your temperature in your state cause in cali its like an inferno lol
Old May 16, 2013 | 01:01 AM
Macurts's Avatar
Seems like a wiring issue, I just shut my car off earlier and the gauge is not working...probably from the shake when it turned off. Got back in my car and its back at peak. When's driving the psi will not drop after driving or anything. Sounds like something dumb is screwed up
Old May 16, 2013 | 06:47 AM
BEKevo's Avatar
sounds wire related. re-do*
Old May 16, 2013 | 01:14 PM
matrho2792's Avatar
After reading everything, it sounds like it's just a bad sensor. Here's a few I found on ebay.
http://www.ebay.com/itm/Pressure-Sensor-Oil-or-Fuel-pressure-sensor-100-Fits-for-Defi-BF-GReddy-/271176964738?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f23681a82&vxp=mtr
http://www.ebay.com/itm/OIL-FUEL-Pressure-sensor-For-BLITZ-DEFI-HKS-TRUST-GREDDY-DFS007001-/321045903842?pt=Motors_Car_Truck_Parts_Accessories&hash=item4abfd3b9e2&vxp=mtr
Old May 16, 2013 | 02:27 PM
BEKevo's Avatar
If your new sensor is faulty, I would send it back to the manufacturer for a replacement. I'd also test the sensor before buying a replacement..
Old May 16, 2013 | 03:32 PM
BEKevo's Avatar
-delete
Old May 16, 2013 | 03:36 PM
Macurts's Avatar
whats the best way to test a sensor? just a multimeter?
Old May 16, 2013 | 05:26 PM
a regular multimeter and you will be fine GL
Old May 17, 2013 | 10:40 PM
BEKevo's Avatar
awdboosted
Nov 9, 2015 05:58 AM
FQ640
Nov 21, 2011 01:49 PM
yesevo
11
Oct 31, 2011 10:19 AM
evo4l
Mar 19, 2009 06:00 PM
EVIL MR
Jul 16, 2008 03:14 PM
