Non HID to HID headlights
Old Sep 24, 2013 | 09:06 PM
boostedrb's Avatar
I have a 2005 evo 8 with non HID headlights in it. I recently bought some HID headlights I have searched on what I need to install them or what extra parts. I want the fog lights to work even the leveling system. That's not as in important though.. Can someone shead some light on this for me and help me out. Thank you
Old Sep 27, 2013 | 09:42 AM
impact blue's Avatar
Is that even possible? I thought that was with projectors.
Old Sep 29, 2013 | 06:20 PM
CN9Adaiski's Avatar
I had the same idea a while back, but Im holding off on it until I get the time to pull off this project. This is just what I know so read and take from this with caution. Basically, I dont have all the answers. This is just what I know from trying to do the same as you are. Also, this is for a 2006 Mitsubishi Lancer Evolution IX, so its slightly different, but I figure most of this will help.
I opened up the area where the headlight leveling and foglight switch is and I saw the connectors there. I already bought the switches and plugged them in, but of course they do absolutely nothing. They are just there so I dont have those plastic blanks. I rather have switches that do nothing than those blanks. When you look at the housing for the HID vs non-HID, they use different connectors. Also, when you look at the fuseboxes in the engine bay, they are different as well. Youll be missing an extra fuse and relay. I bought a complete fusebox and wire harness from a 2006 Mitsubishi Lancer Evolution IX MR to swap in for a OEM HID configuration. Unfortunately, this requires a lot of work because there are a ton of things attached to the fusebox. Also, it would be easier if the engine wasnt in the way. That one is kinda obvious.
So my material list as of today is :
-Headlight leveling switch
-Fog light switch
-Complete HID engine harness with fusebox
-HID headlight housing L/R
Currently on my car, I have the headlight leveling switch, fog light switch, and HID housing installed with working fog lights. I am using the standard halogen bulbs in the housing and I followed a tutorial that allowed me to use the fogs with the fog light switch by wiring the fog light circuit to an external relay and then to the fusebox. Currently, both the headlight leveling switch and the in-cabin headlight leveling ability are inoperable.
Hope this helps and once again, this may not be everything, but this is what I have at the moment.
Old Sep 30, 2013 | 05:33 PM
boostedrb's Avatar
this does help a lot, I went ahead and bought the leveling switch and fog light switch along with the whole headlight harness as well... to least make things easier
Old Oct 1, 2013 | 12:12 AM
MrJuls's Avatar
Does anyone have a pic of the back of the head light where the OEM Globe fits in?
I am in the process of sourcing an HID kit from a supplier but he needs a picture of the back where the globe fits in.The problem is the kits you get don't fit in the normal headlights....
Old Oct 1, 2013 | 12:13 AM
MrJuls's Avatar
Old Oct 1, 2013 | 07:16 PM
CN9Adaiski's Avatar
Yeah having the stuff on hand makes it a lot easier. I need to take the engine out to make the installation step, but thats not happening anytime soon for me. Having just the HID headlight housings for fogs with standard halogens is a lot nicer than it sounds.
Im sure you can find the pic that you are looking for since there are so many pictures to aid people in adjusting the height of non-HID headlights.
Old Oct 1, 2013 | 09:16 PM
MrJuls's Avatar
Yeah,I'll have to do some research then...
Old Jul 26, 2014 | 08:36 PM
Lexus01IS's Avatar
Was headlight harness plug & play?
evoixbri
16
Sep 10, 2015 12:53 PM
DustinDHP
Jul 10, 2015 07:26 AM
ekinshuya
Aug 7, 2014 04:48 PM
JDMonster
22
Mar 19, 2008 09:20 AM
[Neo]
Dec 7, 2007 11:51 PM
