Poured to much ATF SPIII
So..
My AYC reservoir was just under the min level when the car sat for about 90 minutes. I followed some instructions I found on the form to top up.
I bought some Mitsubishi ATF - SPIII and I used a funnel to pour it into the reservoir.. only thing I poured to much.
The reservoir bottled basically overflowed and, the fluid was also dropping from under the car.
I've read horror stories about overfilling this bottle.
Armed with a straw I stuck it in the bottle and put my finger over the top and gradually pulled out enough fluid until it was just under the max mark.
If this happens to you, just use a straw it (it takes some time!)
Yea that works also could have used a turkey baster or this:
