A look at the 4g63 PCV System - Engine internal view
Old Nov 17, 2013 | 03:04 PM
BogusSVO's Avatar
Smile A look at the 4g63 PCV System - Engine internal view
A look at the 4G63 PCV system
Engine internal view.
I know this topic has been covered in depth over and over again.
DSM Wiseman has a great write up on it from the valve cover out, and covers how the system works. If you have not read it, you need to.
http://www.dsmtuners.com/forums/arti...cv-system.html
How this will differ is looking at how what is going to be vented moves through the engine and up to the valve cover.
Now with the 4g63 there are 3 oil returns that drain oil from the head back into the block to the oil pan. One on either end of the head on the intake side, and one in the center of the exhaust side of the head.
Yes air pressure will be vented through these oil returns, the drawback is as air flows up, it will catch oil returning to the pan and catch an amount of it keeping it air born carrying it to the valve cover baffles. This is unwanted oil loss.
Notice the 4 baffle vents that allow the air into the valve cover to be vented outside the engine.
Now if you look at the center of the intake side of the head, there is a vent tower.
Oil is not supposed to flow down this port, but direct crank pressure from the block through the head and direct it towards the valve cover.
The underside of the vent tower
The head vent tower lines up with the dual round passages on the block.
You can see this vent passage cast into the intake side of the block.
Now in the crank case, this is the start of the vent.
Now from what I have seen, the main restriction of this system is in the head, just from casting the head, there is flashing in the vent tower.
When the head is off the engine, the flashing needs to be removed so the crank case can vent as it should.
Now that you have read this, this mod will make more sense.
https://www.evolutionm.net/forums/ev...lock-vent.html
Old Nov 18, 2013 | 04:00 AM
mrfred's Avatar
Thanks for the description. Can you show where the vents start at the bottom of the crankcase? Would be interesting to see where the oil drain lines go as well. Maybe too late to show these since the motor is apparently back in the car?
Old Nov 18, 2013 | 08:10 AM
BogusSVO's Avatar
No, the red block will never make it back in a car, it has a crack in #5 main. It just hangs out so I have one to look at.
The 2nd to last pic shows the start of the vent chamber. But it does not show it in relation of the rest of the block.
It if found on the flywheel side of #3 main.
And appox 3.250 inches below the main cap mating surface.
Old Nov 18, 2013 | 03:52 PM
mrfred's Avatar
Thanks. So it looks like the only difference between the oil drainbacks and the vents are that the vents are in a tower configuration that makes them dedicated vents.
Old Nov 18, 2013 | 06:24 PM
BogusSVO's Avatar
That the same thought I came to. The vents just bring it closer to the VC.
Now from the other thread, what is a oil drain back in a DSM block is a vent in an Evo block.
The center intake vent on a DSM is an oil drain back on an Evo. Also the Evo head has 2 vent stacks on it where the DSM has 1. So I would have to guess that Mits did figure they had a block vent issue.
BogusSVO
Mar 26, 2014 03:59 PM
BogusSVO
Jan 3, 2014 10:22 PM
BogusSVO
Nov 18, 2013 08:18 AM
BogusSVO
Dec 6, 2012 01:10 PM
BogusSVO
Dec 4, 2012 01:45 PM
