Turbo Install question
Old Dec 17, 2013 | 05:10 PM
justin44's Avatar
I am getting ready to install an FP white 71HTA turbo into a 2003 Evo 8 and was looking for advice/encouragement.
I've reviewed the other threads and watched boostedfilms excellent video: https://www.evolutionm.net/forums/ev...all-video.html
so here are my questions:
-How long will a simple swap take with removal of the radiator (on average). I dont have a lift, just ramps. (I am assuming 5 hours to account for frozen bolts and the occasional beer brake)
-I'm nervous about taking off the intake manifold being this car is over 10 years old. I'll use pb blaster and let it soak overnight. I've heard people recommend using heat but am unsure how (I assume blowtorch?)
-which gaskets should I replace? any good source to order online?
I've replaced smaller items like the injectors, fuel pump, and brakes. Is the turbo that much harder?
much appreciated
Old Dec 17, 2013 | 05:13 PM
missmyfdevo8's Avatar
Why white and not green?
Old Dec 17, 2013 | 05:15 PM
And are you planning on running pump gas?
Old Dec 17, 2013 | 05:26 PM
justin44's Avatar
I got an excellent deal on the white from FP that i couldnt pass up. I originally wanted the green but couldnt pass up the deal...
Also, I am in CA and do plan on running pump gas - the 91 oct ****.
Old Dec 17, 2013 | 05:50 PM
Sharkbite2000's Avatar
I can swap a turbo in about 20min flat
Old Dec 17, 2013 | 06:15 PM
rjfg's Avatar
Why are you removibg the intake manifold to inatall the turbo? Did you mean the exhaust manifold?
The first time I pulled the turbo on this car it took less then an hour because the turbo is in front of the motor its so easy.
Old Dec 17, 2013 | 09:01 PM
justin44's Avatar
Sorry I did mean exhaust mani.
I'd pay $150 to anyone in SoCal that would help me install the turbo and licp.
Old Dec 18, 2013 | 10:59 AM
ReaperX's Avatar
It isn't as hard as you're making it out to be. Drop the oil and coolant, drop the downpipe, pull the rad. PB blaster or heat works well, be prepared to possibly break a stud or bolt if you try to turn them too fast. Break all the nuts and bolts from the mani to turbo, and o2 housing to turbo while it is on the car. Put them snug again, remove the nuts from mani to head and pull it out as one unit.
Old Dec 18, 2013 | 11:55 AM
06EvoIXmr07's Avatar
This is as "step by step" as your gonna get.
Use the $150.00 for more beer.
Old Dec 18, 2013 | 02:39 PM
justin44's Avatar
thanks for the help. gonna try to do the swap in the next few weeks
Old Dec 18, 2013 | 11:59 PM
Silver-IXse's Avatar
Pm sent
Old Dec 23, 2013 | 04:23 PM
jrainwater's Avatar
I call bull****. And "if" you could actually do that I surely wouldn't want to drive that car lol.
Old Dec 23, 2013 | 04:40 PM
1UpMoto's Avatar
no need to drain the oil...
Old Dec 23, 2013 | 06:23 PM
heel2toe's Avatar
Notice he didnt say the stock turbo Any v-band setup can be swapped quite easily fyi
Old Dec 26, 2013 | 12:17 PM
neal.johnson's Avatar
changing the turbo just takes patience. think about what your doing and pay attention. very simple
