Evo 8 ssl stereo wiring instructions.
Old Jan 5, 2016 | 01:58 PM
cficare68's Avatar
I have been searching for the better part of an hour now for the instruction to wire an aftermarket cd player into an ssl evo and have no luck. I have the Metra aftermarket harness. I just need to know what the wires goto since mine didn't come with instructions.
Old Jan 5, 2016 | 03:23 PM
edsct9a's Avatar
Usually the metra harness wires are printed with what they go to. Look at the head units manual and it should tell you what each color wire is and just match it to the harness. You won't be using the speaker wires coming off the stereo but the RCAs. You should have 2 harnesses.
Old Jan 5, 2016 | 03:42 PM
cficare68's Avatar
Yeah this one doesn't hence why I stated it came with no instructions...... So here is what I am working with. I am currently trying to install a Pioneer AVH-170 DVD Double Din DVD Player in the car. Here is what I have came up.
Red - 12v Continuous Power
Yellow - Memory/Battery
Blue - Power Antenna
Orange - Illumination (which is optional to use)
Blue/White - Remote to Amp
Can anyone verify that this is correct? Another issue that I am having is that the on the AVH-170DVD Unit there is no wire on its harness for Power Antenna. I have read that this can be tied into the remote wire for the amp if there is not one. Can anyone verify this as well? Cause currently the unit is getting no power at all.
Old Jan 5, 2016 | 03:51 PM
edsct9a's Avatar
Sorry, totally skipped that part. That looks correct and is your ground/black wire hooked up? And yes you can tap the antenna to the remote wire.
http://www.pioneerelectronics.com/St...nual032415.pdf
Old Jan 5, 2016 | 03:54 PM
cficare68's Avatar
I have the ground ran to the chassis of the car. Since I am not seeing one on the harness.
Old Jan 5, 2016 | 03:57 PM
edsct9a's Avatar
It should power up with just the red,yellow and black wires hooked up. Did you buy it used? See if the fuse on the unit is good.
Old Jan 5, 2016 | 05:18 PM
cficare68's Avatar
No I purchased it brand new
Old Jan 5, 2016 | 08:58 PM
edsct9a's Avatar
From the sound of it you have everything hooked up right. Take a pic of the harness.
Old Jan 6, 2016 | 12:15 AM
cficare68's Avatar
I'll have to grab a picture of it later cause I'm out of town today. I tested the DVD player by running it straight to the battery and it turned on so it eliminated the possibility of the head unit being bad. Also going to pickup a multimeter so can check the continunity of the power for the 12v continuos pin.
Old Jan 6, 2016 | 07:11 AM
edsct9a's Avatar
Don't forget to Check the fuse in the engine bay.
karizma23
75
Sep 12, 2009 09:33 AM
dridge11
Oct 31, 2005 01:51 PM
umiami80
Feb 18, 2005 12:04 PM
