GSC Valve Spring Install
Old May 2, 2016 | 08:22 PM
evoniners's Avatar
So I plan on installing new GSC valve springs and retainers along with my new GSC cams. I have read that there is a way to remove the springs without pulling the head off. The way i have read to do this is by applying shop air to the spark plug hole to keep the valves closed. I am curious how much psi of air do I use?
Old May 2, 2016 | 08:33 PM
wheresmyfknmone's Avatar
Try researching the rope method. That way there's no chance to drop a valve in the cylinder.
Old May 3, 2016 | 06:28 AM
LetsGetThisDone's Avatar
Remove the spark plug for the cylinder your working on set that cylinder to top dead center, use the hose from a leak down tester, and pressurize that cylinder to 100psi using shop air, use the tool in the link to change the spring. You may have to use a punch and a hammer to get the original retainers/locks to "break loose". They get a tiny nit of corrosion and need to be unfrozen before the tool will compress the spring without opening the valve. With the piston at TDC, if a valve drops, it wont fall all the way in. But with the cylinder pressurized, they won't drop unless you hit them.
http://www.euroexportinc.com/mitsubi...ing-compressor
Old May 16, 2016 | 06:04 AM
SyZyGy1394's Avatar
Just did mine over the weekend using the rope method and the euroexport tool. Was pretty straight forward!
42revoincali
Dec 6, 2012 06:08 PM
toysgetsmoked
Oct 17, 2010 11:01 AM
11secDSM
Feb 15, 2009 07:15 PM
GregGSC
Nov 9, 2008 11:08 AM
