Making 450hp. What else can I do to make 600ish
Old Oct 13, 2016 | 02:55 PM
timmycat's Avatar
My car is putting out around 450 on speed density with a grime speed 3 port at 27 psi. What can I do to see around 600. I'm trying to avoid the hole e85 thing too. Maybe a bigger turbo.
Current mods are
AMS 30r kit
Tbe
272 bc cams
2.3 stroker
1000cc injectors
deatschwerks 300 fuel pump
Turbo xs intercooler
Ets short route ic piping
Ets ported intake manifold
70mm Full blown Throttle body
Exedy twin
Busher Trans
Spooling up cop kit
Old Oct 13, 2016 | 03:05 PM
Pal215's Avatar
Get the head ported if not done so already, bigger turbo (will add lag), you will need a single walbro 450 or a double pumper setup with bigger injectors. You will have to run either E85, Meth injection (Not recommended), or C16.
-pal215
Old Oct 13, 2016 | 04:10 PM
CurseDSM's Avatar
I agree with pal,your going to need larger turbo, double pumper, better cams being BC cams are crap, larger injectors, better intercooler preferably a Garrett core thats about it. Oh and a good tune.
Old Oct 13, 2016 | 08:15 PM
Bmurray's Avatar
e85 ftw
Old Oct 24, 2016 | 06:58 PM
TOKYO EVIL's Avatar
IIRC, GSC S2's are 276/276? That would be a solid upgrade, IMO.
As stated above, fuel system needs some freshening up. I feel your IC core is fine for your power goals right now. But that's all personal preference at this point.
On a 2.3L, I can see a turbo in the 6266 GEN. 2 class/range being around the ballpark of what you want without too bad of a WAIT:BOOST ratio on 93 oct. (I'm assuming that's the fuel most commonly available to you)
Old Oct 25, 2016 | 01:37 AM
CurseDSM's Avatar
Gsc s2 cams are advertised as 274s not 276s.
Old Oct 25, 2016 | 03:26 AM
TOKYO EVIL's Avatar
Thank you for the correction! I was somewhat unsure on the exact digit, but I remembered it was claimed to be higher than a 272 haha.
Old Oct 25, 2016 | 04:51 AM
e_kobz's Avatar
The original S2's were 272's, the most recent ones are 274
Old Oct 25, 2016 | 03:49 PM
CurseDSM's Avatar
Not a prob glad i could give you a helping hand on some info
Valerie Strong
Mitsubishi TC-SST Discussion
Oct 20, 2016 08:55 AM
Anubis18
16
Jan 3, 2013 07:09 PM
eddie1681
16
Apr 5, 2007 08:57 PM
evoland
Jun 21, 2005 05:58 PM
