How to install an evo8/9 water pump [video]
Request - Drive shaft lobro joint and the importance of protecting the boot. This is something many people are unaware of. I tried the FSM shop cloth trick and every time the shaft bent a little the cloth would pop out.
The water pump install is just bolts and an o-ring - about the same in the car or out. Getting to it is the trick. Its a timing belt job. If you can do a timing belt then no problem. Otherwise farm the job out.
nor11384
Apr 29, 2017 09:25 AM
FS[South]: Evo X water pump, ARP main studs, water pump
honki24
Sep 15, 2016 09:05 PM
han74j
Mar 17, 2004 05:42 AM
