How To Replace Timing Belt - Mitsubishi Evo 8 [video]
Old Jun 7, 2017 | 05:54 AM
DontStopMe's Avatar
Originally Posted by barneyb
Incar, since the right motor mount (the one on the engine) needs to come off, place a jack under the pan to support the engine. Use a plank between the jack and the pan to avoid denting the pan. Once the motor mount is off, the accessory belt idler can be removed by lowering the jack a little. To remove the water pump pulley use a strap wrench. To remove the timing belt idler pulley remove the power steering pump first.
Thanks for the info
Old Jul 3, 2017 | 11:36 PM
Bonnie's Avatar
thanks a lot for the information.
Old Dec 12, 2017 | 08:41 AM
DontStopMe's Avatar
Old Dec 13, 2017 | 02:18 PM
Evo8dagreat's Avatar
good info
Old Jan 23, 2018 | 09:46 PM
4-20sx's Avatar
Great job on the video
Old Jan 4, 2019 | 10:54 AM
DontStopMe's Avatar
Thanks!
Old Feb 20, 2019 | 09:25 PM
strang3majik's Avatar
Thank you for the video/info!
When the balance shaft elimination is done, however, does it matter where the front oil pump sprocket (that used to drive the front balance shaft) is when the belt is installed?
Old Feb 21, 2019 | 07:50 AM
DontStopMe's Avatar
Great question.
I would assume, if you swapped in a stubby shaft, you would not have to worry about setting it with the timing. However, it would be great if someone here on EVOm could confirm.
Old Feb 21, 2019 | 03:14 PM
2006EvoIXer's Avatar
My understanding is that if you remove balance shafts, then position of front replacement shaft won't matter.
Old Feb 21, 2019 | 03:17 PM
And I wouldn't use a stubby shaft because it doesn't provide enough support to resist tension from oil pump gear. Use GSC's billet balance shaft delete.
Old May 7, 2020 | 04:18 PM
Evoguy!123's Avatar
Ticking noise
Hey guys i am having a problem with my evo 8 i replaced the timing belt. Bought gates timing belt kit new. I alined everything properly rotated the engine and waited 25 minutes to see if the grenade pin goes it smooth, and it did. So i went and turn the car on and started doing a ticking noise was wondering if anyone went through that problem.
Old Jun 3, 2020 | 08:49 AM
Fadi Barakat's Avatar
Thanks! just what i needed
Old Mar 21, 2021 | 08:19 AM
DontStopMe's Avatar
Old Apr 7, 2022 | 09:27 AM
Kevin.'s Avatar
This video will come in handy. Sometimes you can't trust anyone but yourself.
pharcydeabc
24
Sep 27, 2020 12:31 AM
bnr34rb26dett
Jan 16, 2016 04:09 PM
bnr34rb26dett
Feb 3, 2015 09:35 AM
fusionchicken
23
Apr 30, 2006 06:08 PM
KK
Sep 2, 2005 05:43 AM
