How to install a speed sensor - video
Old Aug 2, 2018 | 07:20 AM
DontStopMe's Avatar
In-case your speedometer is acting freaky like mine was.
Old Aug 4, 2018 | 08:57 PM
barneyb's Avatar
Two tips:
The speed senor pocket in the transmission casting is a great sand and gravel collector. So, before you pull the sensor you need to blow the debris out of this pocket. Otherwise, its going inside.
Say you're doing a clutch swap and say you've had the plate off the transmission that the rear motor mount bolts to and say you find you cannot reinsert the speed sensor (it takes a lot of says to screw things up). Well, all the bolts for the plate and mount look to be the same length but they are not and you've got a long one up top. There's a tiny bit of length difference and this will prevent the sensor from going home.
Old Aug 16, 2018 | 01:24 PM
barneyb's Avatar
I thought of a third tip. Since I've been working on fuel injectors I've been dealing with electrical plugs with wire bails. When looking at the FSM for transmission pulling, the manual shows (step 3) remove vehicle speed sensor connector. Don't even try, its impossible. Instead, pull the sensor.
Old Jan 4, 2019 | 10:55 AM
DontStopMe's Avatar
Originally Posted by barneyb
Two tips:
Agreed, thanks for adding!
Jaws567
24
Jun 1, 2021 08:25 AM
anthonyrb98
14
May 29, 2012 07:19 AM
nwa7265
Mar 23, 2012 09:46 AM
BoostinBird
May 11, 2010 04:17 PM
Smoku
Aug 17, 2007 06:11 PM
