How To: Change your Brake Pad, or Remove Brake Dust
Tools:
17mm 19mm Wrench
Hammer
small Nail
Tools to take off the wheel
Jack
Brake Pad Hi-Temp Grease A MUST (The Grease will reduce noise and viberation!)
Time: 30mins-1 hour
YOU DO NOT NEED TO BLEED YOUR BRAKES!!!!
Step 1:
Wait for car to cool down!
Step 2:
Jack up the car. Jack point Diff. front and rear
Step 3:
Take off Wheels
Step 4:
On the calipers there are 2 pins holding down a "spring", and the "spring" is holding down the brake pads. Use the small nail put it to the Pin from outside and hit it w/ a hammer! Slow down becareful or else the spring will fly off. Then do the same to the other pin
Step 5:
Next for Rear Calipers use 17mm wrench, Front Calipers use 19mm Wrench. In the back of the Caliper there are 2 bolts remove those.
Step 6:
Pull the Caliper out, careful or else the brake pad will drop!!!
Step 7:
Swap out the Brake Pads, Remove Brake Dusts.
Step 8:
There will be a metal plate for each brake, make sure to look for the arrow on the metal. The driection of the arrow is pointing to the driection of the wheel (forward). Also you will need to apply Hi-Temp Grease! Apply grease to anywhere the metal will touch.
Step 9:
Use same steps to do other brakes.
Warrning: When you frist drive the car, if you were cleaning the rotor or brake pad there might be a brake lag!
17mm 19mm Wrench
Hammer
small Nail
Jack
Time: 30mins-1 hour
Step 1:
Step 2:
Step 3:
Take off Wheels
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Step 9:
500whp.com
87
May 31, 2016 01:30 PM
500whp.com
97
Jan 5, 2005 06:48 AM
