Omni Power 4 and 7 Bar Plug-and-Play Map sensor for the evo 8 and 9
Old Apr 8, 2009 | 08:21 AM
GregGSC's Avatar
Omni Power USA 4 bar (up to 43.5 PSI) & 7 Bar (up to 87 PSI)Plug-And-Play MAP (Manifold Absolute Pressure) sensors for the Mitsubishi Lancer Evolution 8 and 9. Plug and play is right no more hacking up your wiring harness to install a higher rating MAP sensor just plug in the Omni Power MAP Sensor, rescale you cal table and your tuning! This sensor will work with OEM and Stand Alone ECUs.
Sensor
These are state of the art bipolar op amp circuitry with thin film resistor networks built into each micro chip. Pressure changes are calculated on a true linear 0-5 volt scale via a specially designed silicon pressure sensor that also compensates for temperature changes. The unique ability to compensate for temperature changes allows the Omni Power USA MAP sensor to remain a minimum of 99% accurate from 32 degrees F to 180 degrees F through out its range of scale. With the true linear pressure vs. voltage scale there is never a need to re-tune at different altitudes as with other sensors. Competitors sensors on the market don't have true linear scaling which can cause your engine to go out of tune with elevation changes, often resulting in idle problems, poor drivability, and catastrophic engine damage. Omni Power 4 bar MAP sensors can precisely calculate boost pressure from 1-43+ psi (7 bar 1-80+ psi,) while still allowing smooth stock OEM drivability at any boost level. Conveniently packaged in an OEM dimensional housing for easy install and an OEM look.
Key features:
Cases are designed to withstand in excess of 130 PSI without leaking
:-40 to 260 degrees Fahrenheit temperature operating range
:Able to respond from 10% of the pressure scale to 90% of the pressure scale in .001 seconds (the fastest response time of any MAP sensor on the market).
:Automatic temperature compensation.
:True linear scaling for perfect drivability at all boost and vacuum levels.
:Compatible with all aftermarket engine management systems.
:Minimum of 99% accurate over full scale range under all conditions including temperature, altitude, and humidity changes.
:Allows smoother engine operation, higher boost levels, and better drivability than competitors turbo MAP sensors.
irect plug and play for an easy install and an OEM look. Dimensionally identical to the stock MAP sensor.
:Each sensor is hand assembled, pressure, and function checked in the USA for unparalleled quality control prior to shipping.
These are instock and ready to ship!
http://www.stikiller.com/product.php...cat=243&page=1
Old Apr 14, 2009 | 05:06 AM
GregGSC's Avatar
first 5 people will get them for $100 shipped... We are trying to get this a little more in use... awesome product!
Old Apr 21, 2009 | 05:41 AM
GregGSC's Avatar
2 left
Old Apr 21, 2009 | 06:10 AM
R/TErnie's Avatar
Nice product!
Old Apr 25, 2009 | 11:41 PM
skold's Avatar
can you make these replace you maf with a rom reflash>?
Old Jun 3, 2009 | 07:44 PM
R/TErnie's Avatar
check out speed density threads... yes you can.
Old Jul 1, 2009 | 09:27 PM
evofool's Avatar
have any left?
tephra
70
Jul 11, 2024 12:59 AM
Dynotech Tuning
Oct 12, 2012 10:55 PM
03whitegsr
Sep 21, 2012 03:54 PM
Spec-Ops1
48
Aug 7, 2010 04:02 PM
Speed Element
Evo 'For Sale' Electronics / Lighting / Audio
Apr 29, 2010 04:23 PM
