Torque Solutions!
Old Apr 29, 2010 | 10:43 AM
SBR INC's Avatar
Torque Solutions!
Torque Solutions is one of the premiere manufacturers of mounts, bushings and other drive train accessories. These are the small parts that go a long way!!!
We have their entire catalog available and ready to help you get the very most out of your setup!
TS Shifter Cable Busnings - EVO VIII / IX 5 Spd
This popular item is designed to replace the soft rubber bushing found at the end point of your shifter cable assembly. This upgraded bushing greatly improves the feel of the shifter by eliminating that spongy feel you get when changing gears. Easy to install with simple hand tools. Highly recommended when using our Short Throw Shifter.
TS Shifter Bushings - EVO VIII / IX 6 Spd
TS Shifter Base Bushings - EVO X
Torque Solution shifter base bushing kit replaces the OEM rubber bushings on the bottom of the shifter providing a more stable shifter platform and mounting points. This yeilds improved shifting feel and characteristics for years of enjoyment.
TS Drive Shaft Carrier Bearing Support Bushings - EVO I - X
Torque Solution Drive Shaft Center Support Bushings will replace the OEM Rubber mounts with billet aluminum pieces. Doing so will allow for reduced wheel hop, improved acceleration and better E.T's. The mounts keep the propeller shaft from moving under hard acceleration, stopping and turning giving you optimal performance 100% of the time out of your EVO.
TS Engine Mount Insert - EVO X
Torque Solution engine mount inserts for the Mitsubishi EVO X. Inserts can be placed on the passenger side or driver side engine mount.
  • Reduce engine movement
  • Improved 60fts
  • Improved traction
  • 60 durometer urethane
  • Improved e.t.'s
  • Easy installation
TS Billet Front Engine Mount - EVO VIII / IX
Torque Solution front engine mount for the Mitsubishi EVO (VII-IX). This mount allows more energy usually wasted through the OEM material to be transferred to the wheels thus providing better acceleration and redued wheel hop. 1000HP+ Torture tested!
  • Made out of lightweight billet aluminum
  • Black anodizing
  • Reduced wheel hop
  • Better acceleration
  • 1000HP and 8sec e.t. torture tested!
  • Affordable!
TS Billet 4 Piece Full Engine Mount Kit - EVO VIII / IX 5 Spd
Torque Solution complete mount kit for the Mitsubishi EVO (VII-IX). Doesn't get any better then this! This combination of mounts can be seen featured on the some of the fastest evo's in the world. This combo will offer the best performance then any other mount on the market and do so on a day to day basis.
  • Eliminate wheel hop
  • Lightweight billet material
  • Optimal 60fts
  • Optimal traction (tire pending)
  • 1000HP+ and 8sec e.t. torture tested
  • Black anodizing
  • Great for street and race applications
TS Billet 4 Piece Engine Mount Kit - EVO VIII / IX 6 Spd
Torque Solution complete 6spd engine mount combo for the Mistubishi EVO (VII-IX). This is the elite kit on the market. Pound for pound the best you can buy. Torture tested on both street and strip. Want to be first on race day or in the record books. Let Torque Solution make it easier for you!
  • Optimal 60fts
  • Back anodizing
TS Individual Mounts - EVO VIII / IX
We have single mounts available for anyone looking to do something different or in need of just certain mounts!
Let us know about your needs and we'll find the Torque Solution!
Old Apr 30, 2010 | 06:57 AM
SBR INC's Avatar
Free ground shipping all day long on the entire ts catalog!!!!!!!
Old May 3, 2010 | 11:59 AM
SBR INC's Avatar
Lots of great products available from our friends at Torque Solutions! PM me with any questions. Let us know how to earn your business!
Old May 4, 2010 | 10:25 AM
slo4g63's Avatar
pm sent
XTR Performance
Lancer Ralliart Vendor Classifieds
211
May 27, 2014 05:33 PM
XTR Performance
EvoX 'For Sale' Suspension / Brakes / Handling
22
Jul 11, 2012 10:09 AM
XTR Performance
Evo 'For Sale' Suspension / Brakes / Handling
20
Jul 11, 2012 10:07 AM
waskarn
Mar 26, 2011 07:04 AM
newcomer81
Mar 23, 2010 09:06 AM
