Accuracy of MR boost guage....
Old Nov 23, 2004 | 06:01 PM
nabit's Avatar
While riding in my friends MR this weekend I noticed that when the boost hit it would peg out the guage at 1.5 and then drop..My question is how accurate is the guage and also since the guage only goes to 1.5bar when it hits the stop could it in all actuality be boosting more than 1.5?????
Thanks!!!
Old Nov 23, 2004 | 08:22 PM
plokivos's Avatar
what kinda gauge? the stock ones? i wouldn't trust the stock ones. are they mechanical.
Old Nov 23, 2004 | 08:23 PM
Sentinal's Avatar
the MR boost gauges that come stock are the same ones that are an option on the regular Evo they aren't very reliable at all.
Old Nov 23, 2004 | 08:41 PM
fareastkorean's Avatar
they suck, and yes they are the same ones that u can buy through the dealer for the gs-r. Change it now!!! haha I had the factory boost, voltage, etc gauges added with the car deal when I got the car. But I noticed the boost gauge reads really low, when I changed it to hks it reads fine now.
Old Nov 23, 2004 | 10:01 PM
Jakeg97's Avatar
i heard they were bad.
so accuracy is probably really low
Old Nov 23, 2004 | 10:02 PM
oguratevo's Avatar
My gauges reads ok, max boost pressure reads ok as what mitsu claims on the MR specs 20.3 psi = 1.41 kg/cm2 @3500 rpm
Old Nov 23, 2004 | 10:59 PM
plokivos's Avatar
why the hell do you ever need a voltage reading? someone explain that to me.
Old Nov 24, 2004 | 12:33 AM
i dont even know, but the stupid factory gauges, a set of 3 in the cubby hole, comes with a gay voltage reading, not sure what its for either
Old Nov 24, 2004 | 12:41 AM
fromWRXtoEVO's Avatar
1.5 is actually equivalent to 22.05psi. When I use to owned my Modified WRX I was boosting 20psi on 91oct on my FP18G upgrade turbo but when I took the car to have it tune by Dyno-Comp in Phoenix the Dyno Dynamic state of the art Dyno boost sensor was showing 18PSI instead of 20 PSI from my Autometer Boost gauge, that is 2psi of boost difference guys!!.
My point is that you can guess or speculate until you actually have the correct information. You might think that the stock mitsubishi boost gauge option is not accurate but you need feedback to verify it.
my.50c
Old Nov 24, 2004 | 02:48 AM
Derek Baker's Avatar
Evo MR boost gauge
The stock Evo MR boost gauge reads low. The reason that I know is that my Greddy Profec B Spec II Is showing Higher boost than what the MR crappy boost gauge is showing.
My 50 Cents
Derek
P.S. I hope the greddy unit is accurate
