RPS Carbon-Carbon Clutch (Holds 800+ TQ!!) / Innovate LM-1's: $349 Shipped!!
We have the following in stock and ready to ship!! Don't forget about our same day shipping on orders before 2PM EST, friendly customer service and Price Matching.
http://www.wrxevolution.com
- This is the ultimate clutch! Built for the serious racer - drag or track - this twin-disc clutch kit includes everything you need to harness the power and get it through to the wheels. The interlaced twin-disc setup means there's a LOT more contact surface for grabbing and holding on. Initially designed for use in Formula 1 cars, this technology is built for high-horsepower applications. Best of all it comes with 180day warranty! Which nobody offers in a twin or triple disc clutch.
- The average twin disc from other manufactures has a smaller diameter size which is 8" for all wear surfaces and clutch width is 1 1/4". Making this a drag clutch or a clutch that supposed to last a long time doesn't cut the measurement required to do all that. Clutches that are going to be used hard will wear much quicker do to heat caused by friction and uneven surfaces. This will be the premature failure to most clutches that has excessive clutch abuse.
- RPS diameter size which is 10" for all wear surfaces and clutch width is 1 3/4". Pressure plate load is 2100lbs and so the clutch pedal effort is as same as stock and the engagement is much much smoother that stock and is very quiet. Torque Capacity is 800+!!!!!!
- The package comes as a complete assembly - custom chromoly flywheel, multiple discs, pressure plate, flywheel and assembly bolts, alignment tool (which MUST be used during assembly to ensure the discs are centered and straight), throw-out bearing, and even Loctite and a 1/4" drive Allen tool for assembly.
- Full rebuild for the Carbon-Carbon is only $600!!
Thanks!!
-John
john@wrxevolution.com
Innovate Motorsports
LM-1: Digital Air/Fuel Ratio Meter
Tuning an engine for maximum power previously required long trial-and-error sessions on a dynamometer. With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
The instrument can sample and store the air-fuel-ratio and the other sensor data internally in operation for later analysis on a personal computer. At a sampling rate of 12 samples/second the instrument can store up to 44 minutes worth of data in non-volatile memory. The data can be downloaded to a personal computer using a standard serial port and viewed/analyzed by the included software or any standard spreadsheet program:
The Basic Kit includes a the Meter, a Bosch wide-band oxygen sensor and cable, cigarette-lighter power adapter, serial cable for PC connection, 9V battery, exhaust bung and plug, CD and manual.
- LM-1 Basic Kit: $349 Shipped
The RPM Kit is comprised of the basic kit plus the LMA-2 Auxiliary Input Cable. This cable contains a circuit to convert a tach signal into an analog RPM singal that can be logged by the LM-1. This cable also has 4 additional terminal screws to tap into and log other sensors in your vehicle.
- LM-1 RPM Kit: $429 Shipped
The AuxBox Kit is comprised of the basic kit plus the LMA-3 Multi-sensor Auxiliary Input Expander Cable.
- LM-1 AuxBox Kit: $589 Shipped
Thanks!!!
-John
Originally Posted by evoland
exedy rules all!!
Thanks!!
-John
Perrin Boost Tube Kit for 03+ EVO
The Perrin boost tube is a direct replacement for the upper boost tube reaching from the throttle body to the cold side of the turbocharger. This boost tube can conform to tight places if you are using a larger battery isolator. No need for a battery relocation kit. The boost tube kit comes with two intercooler couplers. The kit is avaliable in Red, Blue, or Black.Fidanza Short Throw Shifter
The shorter the throw, the quicker you go! Fidanza short throw shifters have on average a 30% shorter throw. Fidanza's provide precise, smooth, and accurate shifting. They come beautifully polished or Anodized finish depending on the application. This is a full replacement shifter!
Talk about instant power! Aluminum flywheels from Fidanza are about half the weight of the stock flywheels. This means your engine revs faster, and there is less weight on the crank so you are able to get more power to the wheels. Another advantage is they have replaceable faces, so if it wears out, you only have to replace the face for a fraction of the cost of replacing a whole flywheel.
WTT[MidWest]: Gauging interest/WTT RPS carbon-carbon EVO 8 clutch
powerdriver
May 23, 2016 09:16 AM
510Finn
52
Apr 26, 2016 12:08 PM
LogicPerformanc
187
Nov 18, 2005 11:31 AM
WRX EVOlution
Evo 'For Sale' Suspension / Brakes / Handling
19
Apr 20, 2005 07:44 PM
WRX EVOlution
23
Apr 8, 2005 10:29 PM
