New!!! Stillway Engine Torque Dampers, Splitfire Japan Direct Ignition Bridge
Old Mar 29, 2005 | 08:11 PM
evo81's Avatar
would like to know more about the spark plug thing.i'm looking for a damper.the weapon r's seem not to be good.this looks close to the same thing.hmmm...does it come in black or silver??
Old Mar 29, 2005 | 08:21 PM
yf19ex's Avatar
Not to take anything away from the Stillway damper. I have the Weapon R damper. Its a very well put together unit. It works very well. Shifts are smooth and I no longer have that random 1 to 2 high speed shift crunch that tends to happen. This one will probaby work just as well. I have seen them on Stillway's Time Attack EVO So they work just as well in racing as well as the street.
Old Mar 29, 2005 | 10:33 PM
2MANYCARS's Avatar
I would get one if it's possible to get a red dampener to match the valve cover.
Old Mar 30, 2005 | 12:04 AM
Autoxevo's Avatar
Ya, if you can get one in red, i'll take one. (or in silver)
Old Mar 30, 2005 | 05:26 AM
03_05evos's Avatar
Question
Slightly off topic. What upper bar do you have on the car in the pics? I would also be interested in silver. Thanks.
Old Mar 30, 2005 | 06:41 AM
RT's Avatar
RT
...that would be the upgraded factory Mitsu upper bar, very good, well made unit. All alum tubing and welded together not bolted.
Old Mar 30, 2005 | 08:20 AM
speedomodel's Avatar
Awesome, Cal! I've been waiting for you to import that Stillway damper. Sadly, I killed a Honda this morning in my old GSX, and now I'll be paying out of pocket to fix both cars. I'd prefer silver, but, regardless, I'll be buying one in a month or two.
Old Mar 30, 2005 | 08:46 AM
Chris@nolimitmotors's Avatar
order black pleeeeeease so I can get one from preston
Old Mar 30, 2005 | 09:32 AM
BlewBuYou66's Avatar
see the blue one would match my car, but i would also take a red one to go with the valve cover like said above.
Old Mar 30, 2005 | 12:09 PM
Gruppe-S's Avatar
Checking our supplier in Japan for available colors right now. I will keep you guys posted!
Thank you
Old Mar 30, 2005 | 12:25 PM
evo81's Avatar
Thank you
please do. i would order a black/silver one right away
Old Mar 31, 2005 | 12:57 AM
jbigelow's Avatar
thanx cal!!!!!
sorry that i couldn't purchase the DI bridge. as you saw today, i have enough grounding and voltage wires with the sun automobile hypervoltage and hypergound. but if i didn't have the sunautomobile hypervoltage and hyperground, i i would be all over this di bridge from splitfire.
the drive home from hayward to sacramento was a treat!!!!!
shifting was smoother and quicker and i don't have the 2nd gear grind anymore while speed shifting!!!!!!
this is a MUST mod.
gruppe-s is top notch!!!!!!
thanx for the install help too!!!!
-jbigs
Old Mar 31, 2005 | 04:39 PM
Gruppe-S's Avatar
Originally Posted by jbigelow
thanx cal!!!!!
this is a MUST mod.
-jbigs
thanks for the testimonial glad it helps you out
Old Mar 31, 2005 | 05:35 PM
h22gordo's Avatar
Finally someone imported these!
Thanks Cal!
I contacted Stillway via email months ago, they never got back to me!
Old Mar 31, 2005 | 06:52 PM
Gruppe-S's Avatar
Thanks Cal!
yup yup! Please give me a call if you want one! I am taking orders
Thanks
Cal
