New!!! Stillway Engine Torque Dampers, Splitfire Japan Direct Ignition Bridge
Old Mar 29, 2005 | 05:41 PM
Gruppe-S's Avatar
Hey guys,
These hot new items just came in!
Fully aluminumized casing w/ heavy duty piston design. Mounting plates are forged aluminum. Available color: Blue.
Tighten your engine chassis and eliminate unwanted movement of your engine under hard acceleration and during hard cornering. Also improves shifting engagement.
Comes with heavy duty engine damper, engine chassis plate and strut top plate to secure installation.
MSRP: $220, On sale now $199 shipped!
Splitfire Japan's Direct Ignition Bridge
This system helps eliminate negative electric current/statics and smooth out ignition sparks to provde better fuel economy and improves idle and engine torque. Also works as grounding kit. Very trick product! Only available in Japan..now available thru Gruppe-S!
MSRP: $300, On sale now $285 shipped!!!
I only have a few available now, Please give me a call to order!!
Thanks
Cal
Old Mar 29, 2005 | 06:36 PM
Autoxevo's Avatar
Are the dampeners only available in blue? And is it that a plastic body or metal?
Old Mar 29, 2005 | 06:48 PM
Gruppe-S's Avatar
I believe other colors can be ordered as well. I only got the blue ones in..
The overall body is made out of aluminum.
Thankyou
Cal
Old Mar 29, 2005 | 06:49 PM
BlewBuYou66's Avatar
do you have any shots of this installed or anything? do you think it is better or just the same as the weapon r unit?
thanks
Old Mar 29, 2005 | 07:02 PM
Gruppe-S's Avatar
Here are some pix of this damper installed on my car. IMHO, the overall construction is wayyy better than the other ones on the market.
Old Mar 29, 2005 | 07:11 PM
it looks like there might be a little issue with an aftermarket sway bar, or maybe its just the angle, also do you have to remove cam cover for installation.
Old Mar 29, 2005 | 07:12 PM
also, thanks for the great pics!!!! they really help people decide on wether to get the parts or not. at least it helps me.
Old Mar 29, 2005 | 07:16 PM
Gruppe-S's Avatar
No issue w/ aftermarket strut bar at all. The mounting plate goes underneath the strut bar. It works on my strut bar and so should work w/ yours
No need to remove cam gear cover for installation. THe cam gear cover is not on because im running HKS cams/cam gears.
Thanks
Cal
PS.. 1 engine torque damper left!!
Old Mar 29, 2005 | 07:20 PM
ok thanks, if i dont order one now or by the time there all gone when do you think you'll have more of them? thanks
Old Mar 29, 2005 | 07:26 PM
EvilBlueEvo8's Avatar
Well first off I think he means strut bar. Will it work with an aftermarket strut bar like the Cusco Ti? I'm also wondering if you need to remove the came cover to put this on. I've wanted a Stillway for a while now (I refuse to use stuff like Weapon R on my car) and I tried to get one through another supposed "speacialty import" vendor. They can never get anything in their catalog. Well you guys have it now and I'd like to get one in blue if you can answer those questions for us. Thanks.
Old Mar 29, 2005 | 07:32 PM
yup, strut bar was what i was looking for. a thousand pardons, good sir.
Old Mar 29, 2005 | 07:54 PM
sleet's Avatar
Do these things actually do anything?
Old Mar 29, 2005 | 08:02 PM
Gruppe-S's Avatar
I have more on its way!!! thanks!
Thanks
Cal
Old Mar 29, 2005 | 08:07 PM
Gruppe-S's Avatar
Yes it will work w/ aftermarket strut bars. There is plenty of room due to the design of mounting plate. The damper itself is in blue. I might be able to different colors too, but I have to check to make sure.
As for cam gear cover, You do not need to remove the cam gear cover to install this torque damper. I will post some pictures of this damper w/ cam gear cover installed. Stay tuned!
Thanks
Cal
Old Mar 29, 2005 | 08:08 PM
Gruppe-S's Avatar
yes. engine damper prevent engine from moving under hard acceleration and tight cornering. Also stiffens up the chassis dynamics
Ignition bridge provide better grounding and ignite better spark efficiency.
