ACT and Exedy clutches in stock and ready to ship.
Old Jul 7, 2005 | 01:33 PM
GNV Motorsports's Avatar
Hey guys just got a few clutches in stock. Got some for street/track use to your track only clutches.
ACT Street Disc 03+ Evo: $525 SHIPPED!
ACT Heavy Duty Pressure Plates provide increased torque capacity, durability, and extended clutch life. What makes ACT Pressure Plates the highest standard in the industry? First, ACT manufacturing always begins with new units. Second, pressure is increased the right way. Altering the geometry alone is not enough. Instead, ACT engineers a stronger diaphragm. ACT diaphragms are heat-treated using an exclusive 3-stage process and the release bearing contact area is hardened to reduce wear. Third, ACT designs the pressure and release travel of the unit to be in the optimum working range. Every unit ACT produces is accurately balanced and tested. ACT Street Discs are designed for smooth engagement, quiet operation and improved durability using only the best organic, spring center designs. ACT Performance Organic Street Discs use special performance linings designed to withstand high heat and abuse.
* Includes heavy duty pressure plate, performance organic street disc, release bearing & alignment tool
* 38% increase in clamping force over OEM pressure plate
* Torque capacity of up to 497 lb-ft
ACT HD 4 Puck Disc Kit - 03+ EVO: $500 Shipped!
This kit includes these components:
MB017 - Heavy Duty Pressure Plate
4P240H - 4 Puck Race Disc
RB601 - Release Bearing
AT03 - Alignment Tool
Torque Capacity: 636 ft
/lbs.
Exedy Twin Plate Clutch/Flywheel Kit - 03+ EVO $1548 SHIPPED!
For high-powered applications, EXEDY offers twin and triple Multi-Plate Clutches. These are designed for hot street action as well as drag, road and rally racing.
The twin plate clutches are rated for above 500hp to 750hp. The triple plate clutches are rated for up to and over 1000hp (for drag race applications). Twins come as with both spring damper discs and solid discs. Triples are all solid discs.
All Exedy multi-plate clutches come with a lightweight, chrome moly steel flywheel and the famous purple anodized forged aluminum clutch cover. Depending on the application, we have both strap drive and lug drive models. All have T5001 cerametallic friction materials for extreme heat resistance.
Engine modifications e.g.. cam-timing-turbo modifications etc. cause engine pulsation and vibrations. These vibrations can cause clutch rattle when the clutch pedal is depressed by movement on the intermediate separator plate in some applications. These noises will in no way affect the performance of the Exedy Multi Plate Clutch. This rattle is well accepted in the performance industry where engine modifications have been carried out.
* Includes pressure plate, twin clutch packs, chro-moly steel flywheel
Exedy Hyper Single/Flywheel Kit - 03+ EVO
For high-powered applications, These are designed for hot street action as well as drag, road and rally racing.
EXEDY Corporation/Daikin Manufacturing Company, is the largest independent OEM clutch supplier to the Japanese automotive market. EXEDY supplies clutches to all major Japanese auto manufacturers and is Japan's leading supplier of racing clutches. Consistent with their normal tradition of quality, all EXEDY racing and performance clutches are designed, engineered and built as race clutches - not rebuilt from stock clutches. Kit includes Clutch Kit, and flywheel. Fits Turbo Lancer EVO 8. Kit DOES NOT Include Throwout bearing.
We also price match! ACT 6 puck and Exedy Triple plates availible as well PM us for those special prices.
Steve
GnV Motorsports
Old Jul 8, 2005 | 10:22 AM
Back up top.
Old Jul 8, 2005 | 03:32 PM
Bump. One ACT street disc down only a few more left!!!
Old Jul 11, 2005 | 10:41 AM
Bump. We price match as well if you think we are offering prices to high
Old Jul 11, 2005 | 11:52 AM
smokey's Avatar
Does that come with a flywheel? if not do you have flywheels? and how much for one.
Old Jul 11, 2005 | 12:33 PM
pm'd you!!! :-D
Old Jul 12, 2005 | 12:49 PM
bump
Old Jul 13, 2005 | 09:54 AM
Bump. PM for even lower prices
Old Jul 16, 2005 | 11:16 AM
Bump
Old Jul 18, 2005 | 12:17 AM
Bump only offering prices til wednesday.
Old Jul 18, 2005 | 10:20 AM
Bump
Old Jul 19, 2005 | 09:30 AM
drc's Avatar
drc
any chance you have an exedy triple?
Old Jul 19, 2005 | 11:50 AM
No no exedy triples in stock. But if you would like shoot me a pm and i can get you an eta on when we can get one to you. :-D
Steve
GnV Motosports
