Clutch and Radiator Blowout!!
Evo Clutch's! Exedy and ACT!
1 IN STOCK!! Exedy Twin Plate - HD Type in stock! For 1575 shipped!
Stage 3 EXED MM022HD
We have two ACT HDG6 - Heavy Duty with Sprung 6 Puck Disc! For 528 shipped!
Turbo, AWD, 636 lbs. 38% Pedal Increase, This kit utilizes a Heavy Duty Pressure Plate superior to the stock pressure plate. The clutch disk is made of a copper ceramic material which holds approximately 28% more torque than an organic lining. ACT Copper Ceramic Xtreme Race Discs engage fairly harsh and are not recommended for street use. ACT recommends 6-pad ACT Xtreme Race Discs for larger sizes to absorb more heat and for smoother engagement. The 4-pad ACT Xtreme Race Discs engage harsher, shift faster, and are well suited for smaller disc sizes from smaller engines. All clutch kits include throwout bearing and alignment tool (if applicable).
We have the NEW!! Fluidyne Aluminum Radiators!! for 389 shipped! VII, VIII 1 1/2" tubes 28"x19.73"x2.0" 1.5" in/out, 12lbs
From race circuits to street cruising, FLUIDYNE High Performance now makes its race-bred fluid cooling technology available for the fastest and most powerful vehicles on the street. FLUIDYNE has coupled its racing technology with street smarts to develop the optimum "Direct-Fit" all-aluminum radiators for these special breed of vehicles. FLUIDYNE radiators feature CAB-brazed (no epoxy) core construction, polished aluminum tanks and durable high efficiency air fins for maximum cooling capability across the full range of city, highway and road course driving.
We have three PWR Racing Radiators for 459 shipped!!
This beautifully polished all-aluminum radiator features a 40mm thick two-row core that gives high-hp vehicles the extra cooling capacity they need. The stock height and width allow for a factory-like installation, and brackets are included that make use of the factory cooling fan as well. Vehicles with automatic transmission may need to run an external transmission fluid cooler as well.
We have one Koyo Radiator for the EVO 4/5/6 429 shipped!
KoyoRadiators are fully polished to a mirror finish. Provide 20% to 30% more cooling than standard radiators. Handles high revving, high performance motors.
Perfect for Turbo Charged, Super Charged & Nitros Oxide equipped engines. Made from aircraft quality aluminum and Heli-arc welded, cores are NOCOLOK-brazed. Koyo Radiator is on the cutting edge of technology and design with Japan's largest automobile manufacture. Custom built OEM fit - All Koyo Radiator cores and tanks are specifically designed and built for each application. No universal fit parts are used.This ensures proper fit, just like your original equipment!
If you have any questions feel free to call or ask! DSM ftw!
interested in the ACT Xtreme Clutch. What is it's torque rating? Will it fit my IX MR? Is it streetable? I am looking for a clucth that will take alot of torque, shift high, and handle a turbo upgrade. And yeah last atleast 60K like my HDSS did before I sold my Evo.
Thanks for posting.
