Power Enterprise! What!! Check It Out!
The largest injector supplier in Japanese tuning market
* Offers unique design of multi spray port injectors
* Power injectors pulse wave matches precisely to the ECU
* The most prefered spray patterns for the race cars (Special spray patterns developed exclusively for Power Enterprise)
PWR offers “top feed” and “side feed and the multi spray ports injectors. The 1 & 2 spray port paterns, depending on the engine's intake port system are PWR's unique designs. A typical hi-efficient DOHC 4 valve engine has two port intakesystem which the PWR two spray port injector can be greatly benefited. Multi spray port injectors are designed for higher level of combustion by avoiding atmized fuel hit on the wall of a intake port and flowing in dropplets. The injector sprays fuel in 150-200 microns on the back of a valve head without hitting against the wall of a intake port. When the injector size becomes larger the mentioned problem become worse, but PWR developed unique two ports injectors to minimise the inefficiency for many of today's engine applications. The fact is when it's compared to the same amount of fuel passing through the PWR big injectors and the out put horse power for any engine, none of other injectors can compete.
The part number begins by " T" indicates top-feed type injectors and begins by "S"refers to side feed type injectors. The image far right shows two nozzle spray patern on the two port intake system
MSRP: $520
PRICE CASH OTD: $442
The cores of radiators in the market has been thickened from single to double row, double to triple row, increasing the volume of coolant. But the disadvantage with the thick cores is restriction of the air flow, passing through the fins, consequently the cooling efficiency becomes worse and the temparature in the engine room become high. We all know the #1 factor for any mechanism failure is "HEAT". The heat deteriorates the engine performance and the integrity of material structure. The solution to the mentioned is the PWR lightweight, low cost, all-aluminum Double Row Radiator.
FEATURE 1 : All-aluminum, Double Row, Large Capacity & Light Weight Radiator
FEATURE 2 : High efficiency fins
Analyzing water flow, we decided the optimum fin pitch, fin height, and louver pitch. Turbocharged cars, for example, have an intercooler or a condenser blocking off cool air in front of a radiator. Furthermore, heat tends to stay between an intercooler and a radiator, so the efficiency of the radiator is difficult to be displayed. PWR developed a radiator considering how to prevent heat, send cool air smoothly to the engine room and control rise in temperature . These are especially effective when driving in expressways at high load and provide high output, stabilizing the temperature of water and lowering the temperature of the air taken in to the engine room.
FEATURE 3 : Highly reinforced thin flat tube
We developed thinner, stronger material for radiator tube. Aluminum is difficult to radiate, so we made tube thin in order to greatly improve radiation.
Upper Tube: $69
Lower Tube: $88
Complete set: $144
Tubes and Radiator: $725
Power Enterprise High Flow Fuel Pump, the most reliable and popular among top tuners in Japanese race field. Please see the flow characteristics of 245L/H pump below if it's maching to your target HP (Fuel Consumption rate) . Minor modification required for installation
Price: $144
PWR SUPER V-BELT
The first and the original KEVLAR belt manufacturer
released the most advanced V- belt in the world !!
Heat resistance Improved 4-times superior to the stock!
Slip resistance Improved 3 times resistive than the stock!
DurabilityImproved twice as much as stock!
Frictional resistanceMore than twice than the stock.
Price: $83
Lan
Lancer Evolution 4G63 RX6R Setup KIT
RX6R, a compact and light weight ball bearing turbine, known for the Formula-1 racing is now available through Power Enterprise the largest IHI turbo distributor in the world. With engine upgrades, it can produce well over 600 wheel HP. The exhaust and compressor housings can separately be selected and matched to stock to oversized for each engine applications. The 4G63 RX6R kit can be installed on the vehicle types CN9A / CP9A / CT9A with stock intercooler by fabricating your own inlet and intercooler piping, An application for the CT9A model come with inlet pipe and air filter system (call full kit). Large volume fuel pump and injectors are sold separately Setup Kit consist of RX6R turbo, Stainless EX manifold, Outlet pipe & Front pipe, Waste gate valve, Oil lines, Gasket set and hard wares.
Applicable Engines: 4G63(EVOⅣ~EVOⅨ) Power Capability: 450HP~650+HP(depending on the engine's strength upgrades)
Price: $5100
FS[Northeast]: Brand new Koyo Rad
thedru13
Aug 14, 2015 03:48 PM
Vivid Racing
25
Apr 23, 2012 09:46 AM
Mr.IX
For Sale - Cars For Sale
13
May 2, 2011 09:20 AM
fiaevo.com
15
Jun 9, 2007 09:54 PM
