EVO Test Pipe CEL Fix In The Building
Old Apr 19, 2004 | 04:57 PM
LancerShop.com's Avatar
Gold Sponsor
Lightbulb EVO Test Pipe CEL Fix In The Building
Hey Guys,
www.LancerShop.com is pleased to announce the arrival of EVO CEL fixes. If you are running a test pipe and throwing a check engine light; we have the answer for you.
- EVO Test Pipe CEL Fix -$68.95
After the installation of a catless test pipe, your EVO computer tends to throw a CEL due to a lack of catyltic converter effiency. This kit will make the Check engine light disappear. Installation takes about 1 hour and has to be spliced in the existing wiring. OFF ROAD USE ONLY.
Click here for more info
Order online securely 24/7 or give us a call toll free 1-800-488-9174.
Thanks
www.Lancershop.com
Old Apr 19, 2004 | 06:41 PM
MYEVOVIII's Avatar
So will this be installed inside the car or underneath it?
Also it appears it needs to be grounded is that correct. Can you show installed pic or even directions so I have better idea?
Old Apr 19, 2004 | 08:56 PM
Quickshift's Avatar
Sweet about time!!!!!
Old Apr 20, 2004 | 11:07 AM
eve-slow's Avatar
So essentially this just eliminates the light on your cluster, and does not adjust anyting in your ECU, right? The CEL doesn't affect performance or reliability?
Old Apr 20, 2004 | 11:12 AM
Evo Spec VIII's Avatar
its probably just an o2 simulator, which sends signals as if the cat was there to the ecu so it still thinks the exhuast is fine and within the factory set limits. so the light then goes off after a few days if its been on and stays off. i have one on my se-r spec v works perfect.
Old Apr 20, 2004 | 01:42 PM
eve-slow's Avatar
Thanks Evo Spec VIII! My Integra has a test pipe and doesn't throw a code, but it is OBD 1. SO the ECU won't try to adjust for the simulated signal?
Old Apr 20, 2004 | 01:49 PM
WannaRace's Avatar
Just take out your passenger seat for some working clearance, bring up the 02 connector from the carpet, and splice away.. It's really easy, got it done in at least 30 mins...No more CEL
Old Apr 20, 2004 | 08:03 PM
dryad001's Avatar
So what you people are trying to say is that this will eliminate the rear 02 sensor. If so that will be a perfect spot for a wideband 02, no need to weld in a new bung.
Old Apr 20, 2004 | 09:03 PM
silver8's Avatar
Attn: LancerShop.com
I Tried to order it but it keeps coming up as "$179.00 perrin cat delete" at the check out. How can i correct this?
Old May 7, 2004 | 03:35 PM
MitsuJoe's Avatar
isnt that too far down the exhaust stream to put a wideband?
Old May 7, 2004 | 05:49 PM
evo542's Avatar
actually the further down the o2 sensor is, the longer it lives
Old May 7, 2004 | 09:18 PM
Nad1370's Avatar
Nope . thats where Al puts his wide band O2 for his custom tunes
Old May 10, 2004 | 03:07 PM
Gold Sponsor
still have a few left at our shop, with another shipment on the way.
THanks for all the orders
Old May 16, 2004 | 03:01 PM
Gold Sponsor
More in-stock and ready to ship.
LancerShop.com
21
Jun 7, 2004 08:29 PM
LancerShop.com
76
Apr 24, 2004 07:30 PM
LancerShop.com
Mar 1, 2004 12:19 PM
LancerShop.com
Nov 30, 2003 07:31 PM
LancerShop.com
Nov 23, 2003 07:18 PM
