woofer?
Old Sep 23, 2004 | 11:21 PM
dizzigital's Avatar
woofer?
hey guys... what's a solid woofer with super tonage? i loved the 12" round solo-barics...
Old Sep 23, 2004 | 11:25 PM
Dookie's Avatar
If you like Kicker, the CompVR series is good for SPL. Not good for SQ though. How much are you willing to spend? One or two of them? ported or sealed? Can go many different options...
Old Sep 23, 2004 | 11:42 PM
dizzigital's Avatar
wasn't the solobaric SQ as well? or maybe SQ AND SPL, sure sounded like it... money is not the problem, but the amp is... it's a phoenix gold ti800.1 tested at 934 RMS. so the best the amp can handle i guess... two of them and sealed...
Old Sep 23, 2004 | 11:47 PM
Sentinal's Avatar
I swear by JL audio after trying kicker orion fosgate JL in my car I wont touch anything But JL from now on. They hit hard they are crisp and clear and are awesome for SQ. Depending on your style and price range they have several options as well.
Old Sep 23, 2004 | 11:55 PM
dizzigital's Avatar
hmmm... so JL it is then huh... i've been thinking of others, but the solo's are square now (EH)... what the hell is a square woofer good for other's were too soft and i don't think i can get those round solo's anymore... so JL it is?
what kind of options are you talking about?
Old Sep 24, 2004 | 12:00 AM
Sentinal's Avatar
well for someone on a tight budget the W0's are their entry level sub then there are the W3's which are a little higher priced and made to run very efficient clean sound with moderate level of power then there is the W6 which is a little higher power and hits harder and is almost as clean as the W3 then finally the W7 which is their SPL sub which hits freakin insane hard but isn't as clear as the others but still better SQ than most SPL subs on the market. For me I went with the W3's because they were the cleanest sound but it takes all 3 of mine to keep up with 2 of the W6's or 1 of the W7's in terms of decible level.
Old Sep 24, 2004 | 12:08 AM
dizzigital's Avatar
hmmm... did you get the W3 or W3v2? what's the wattage and what's the decibel level?
Old Sep 24, 2004 | 12:10 AM
dizzigital's Avatar
which is cleaner and which is more powerful of the two?
Old Sep 24, 2004 | 12:14 AM
dizzigital's Avatar
oh... and is it bad to have a 5 farat capacitor when I don't even have 3000 watts pumping at once? i just wanted to play it safe, lol....
Old Sep 24, 2004 | 12:18 AM
Sentinal's Avatar
they are pretty much the same sub V2 just means dual voice coil so that you can wire them for different amounts of impedance depending on the number of them you have and the amplifier you are using... my setup I have 3 10" w3v2 set up so that the amp see's about 3 ohm of impedance the JL amp I have is designed to run off anywhere from 2-4 ohms with the same continuous output. The max RMS power rating on these subs is 250 watts a peice however if you feed them a clean signal they can handle a lot more than that. SK lancer is running 1500 watts to a single JL W3 I don't know if I would recomend running that much power but he hasn't blown it yet so that speaks highly of the sub. I run about 600 RMS watts to the 3 subs I have and it sounds great.
Old Sep 24, 2004 | 12:23 AM
dizzigital's Avatar
wow... 600 RMS for all three subs? that **** must be CLEAN. i heard 2ohm speakers are cleaner... is this true?
Sentinal's Avatar
if your using W3's you wont need to be anywhere near 3000 watts... capacitors work like mini batteries and are basically a bandaid for systems with power problems. The way they work is they get charged and hold that charge until they are discharged. Having a cap in the system can help if your battery is unable to supply enough charge to the amps the cap will help supply some of that juice then recharge off your battery (caps charge and discharge extreamly quickly usually under 1 second). I run just a tad under 1000 watts RMS in my system and I don't need a cap at all I have even talked to professional published installers who have said they set up 3000 watt systems with no cap at all. So if your battery can handle the power your system draws then don't even bother with a cap if it can't then add a cap or consider a battery upgrade (which may require alternator upgrade)
Old Sep 24, 2004 | 12:25 AM
Sentinal's Avatar
2 ohm vs 4 ohm doesn't really make a difference what makes the difference is the setup you have which amplifiers you run how clean your deck signal is how good of RCA and other wires/connectors you use and the box you put the subs in all make a big difference 2 vs 4 isn't really a concern whatever your amp is set up for will be best to run.
Old Sep 24, 2004 | 12:34 AM
dizzigital's Avatar
well, there's a total of 3 amps... actually now that i think about it, i think i've got only 2000 watts... what the? does it sound better with a new battery or a new capacitor or it'll sound just as good as long as the stock better can handle it?
Old Sep 24, 2004 | 12:37 AM
Sentinal's Avatar
as long as the stock battery can handle it should be no problem hook a volt meter up to the battery and if it drops more than .5 volts when the subs hit then the battery needs help
