good amp for subs?
Old Nov 9, 2004 | 01:55 PM
importstylz07's Avatar
good amp for subs?
what would be a good amp to use with two apline type R's (1241D)
I was thinkin about runnin 600watts to each sub...Any suggestions??
Old Nov 9, 2004 | 02:39 PM
cagedweller's Avatar
i am selling my sony XM2200GTX. -
Maximum Power Output @ 2 Ohms Stereo: 2 x 600 Watts
Maximum Power Output @ 4 Ohms Bridged: 1 x 1200 Watts (peak)
Continuously Variable Crossover From 50 Hz to 300 Hz
variable bass boost (0-10 dB at 40 Hz)
40Hz EQ boost
MSRP was $249 when i bought it early summer- ill let it go for $125
only used for 4 months. getting rid of it cause i dont want the weight of subs or the pull on my battery
Old Nov 9, 2004 | 06:59 PM
Mitchubishievo's Avatar
You can never go wrong with JL...and Sony makes good portable and home electornics, but surprsingly they are a company to stay away from when it comes to car audio.
Old Nov 9, 2004 | 07:13 PM
dcorn's Avatar
There is a 1200 Watt amp for $250??
Old Nov 9, 2004 | 10:53 PM
what brand would ppl recomend here..?
Old Nov 10, 2004 | 07:54 AM
stiklr's Avatar
memphis 16-mc1000d
it is rated RMS at 300 x 1 @ 4 ohms, 600 x1 @ 2 ohms, 0r 1000 x 1 @ 1 ohm
It gives you flexiblity on set up and it is a small sized amp with loads of clean power. Check it out http://www.memphiscaraudio.com
Old Nov 10, 2004 | 08:11 AM
James's Avatar
momphis is a good amp
james
Old Nov 10, 2004 | 09:08 AM
cky3396's Avatar
ive got just one JL 12w6v2 sub powered by a JL 500/1 and it hits suprisingly hard. its silly, just silly
Old Nov 10, 2004 | 09:19 AM
any one heard of re XXX subs?
Old Nov 10, 2004 | 12:44 PM
dcorn's Avatar
I need a more powerful amp. I had a 8" kicker compVR hooked up to a MTX 251D runnin about 250W, but blew the sub somehow. I replaced it with a Kicker 8" L7 () which can take up to 450W RMS. Any ideas on an amp that will run 450 W @2ohms for relatively cheap?
Old Nov 10, 2004 | 02:27 PM
NapervilleEVO's Avatar
sony way overates there power. max 1200 divide that by two for realistic output, and then divide that by two b/c it sony 300 watts. b/c its sony means you could get a 600 watt audiobahn that would be just as good if not better then a a sony 1200. i have a sony explode with two 10 L7 kickers so i speak from expeience.
Old Nov 10, 2004 | 04:01 PM
Forbiden's Avatar
Yeah but what does that have to do with his amp question?
Anyways, I have a bostwick 250.2 running to each of my alpine type R's. The amp runs 480 watts bridged at 4 ohms and is decently priced if you can find a dealer.
Old Nov 10, 2004 | 11:51 PM
just wondering
Old Nov 11, 2004 | 12:14 AM
ilovecb23's Avatar
jl is always good to go with
Old Nov 11, 2004 | 12:29 AM
yeah if your sponsored or rich
