How do you take off factory shift knob?
Old Dec 8, 2004 | 03:47 PM
steve0677's Avatar
Originally Posted by LancerEVOmann
Ok, but I discovered that after I unscrewed the screws by the accelerater under neath that panel there is a screw with no indents to take it out there that holds the lower panel of the console on. How do I loosen these?
Or is the top part of the console (the part with the ashtray) just connected by plastic and it will just pop out? I dont' want to ruin anything by doing this.
just the top part
Old Dec 9, 2004 | 07:28 AM
rsboy's Avatar
Originally Posted by ultraflip
hahahaha... omg.... hahahahahahaha.... turn car counter clockwise... ahahahhahah...
what?!?!? You are so wrong! If you hold the knob and turn the car counter clock wise... you are tightening the knob! hold knob and turn car clockwise will loosen the knob. Lefty-loosy baby!
Old Dec 9, 2004 | 07:37 AM
ultraflip's Avatar
Talking
left = counter clockwise
righty tighty
lefty loosy
lol
Old Dec 9, 2004 | 07:38 AM
Ev0 1's Avatar
Why do you need to take the shift boot off to install a shift knob? Can you post a pix of the knob you got?
Old Dec 9, 2004 | 07:39 AM
Ev0 1's Avatar
righty tighty
lefty loosy
lol
Yeah but if you hold the knob and turn the car counter clock wise, its just tightening the knob. If you turn the car clock wise it'll loosen the knob.
Edit: try it with a soda bottle.
Old Dec 9, 2004 | 07:52 AM
UFO's Avatar
UFO
Wow. Do you have someone who can help you? Seriously, this is quite possibly the easiest install ever and you're struggling with it. My 8 year old son could change the shift knob... Why are you removing the center console to install a shift knob?
The 'screw' you are referring to is probably a plastic push pin where you have to depress the center of the pin and then pull it out.
Old Dec 9, 2004 | 08:21 AM
ultraflip's Avatar
Talking
hahaha... i had to go out and buy a soda.... ad dang you're right... hahahhaa... kudos bro!
this thread is helpful after all... hahaha.... then again... i can change my own shift knob just fine
Old Dec 9, 2004 | 11:25 AM
rsboy's Avatar
heheh... you did say "turn car counter clockwise"
you do learn something everyday here on Evom! and learning is half the battle.
Old Dec 9, 2004 | 11:50 AM
machron1's Avatar
I guess the instructions in my previous post from the ricer's maintenance manual were confusing, so I will quote it exactly:
  1. Open sunroof. If car is not equipped with sunroof, you must drill a 6" hole in the roof over the shifter mechanism. Use a rusty hole saw ghetto rigged to an electric drill with duct tape.
  2. Attach holding fixture, PN 1D10TR1CER, to shop ceiling.
  3. Attach other end of holding fixture to the shift knob through the sunroof or new 6" hole.
  4. Lift car and place dollies under all 4 tires. If no dollies are available, skateboards or rollerblades can be used. The self-adjusting duct tape mechanism on the holding fixture will adjust for any height difference.
  5. Rotate the car in a clockwise direction as seen from above until the shifter knob comes loose. If no clock is available for reference, see section entitled: Clocks - What are they?
  6. Remove fixture from shift knob and ceiling.
  7. If a hole was drilled in the roof, cover with the largest APC sticker available. Optionally, you may cover the hole with an unpainted fiberglass roof scoop.
Old Dec 9, 2004 | 02:51 PM
machron1's Avatar
Wow tough crowd...
Old Dec 9, 2004 | 04:00 PM
LancerEVOmann's Avatar
I was going to see if I could cut the bolt down because the MOMO knob is like 2 inches taller than the stock shift knob, so the whole shifter is really tall now with the Momo knob on. Its like a Mack truck shifter. Turns out I'm just gonna buy a short shifter. I didn't think the Momo would be that much bigger.
Old Dec 9, 2004 | 04:05 PM
I did not think the MOMO knob would be like 2 inches bigger than the factory knob, so the whole shifter is really tall now. Like a Mack truck shifter. I was going to take out the factory shifter and machine it down, but I'm just going to buy a short shifter now. Plus I cannot put on the bottom thread ring on the MOMO bc when I press the knob all the way to screw the screws in there is no room for the thread ring.
Thanks anyway smartass, thats good your 8 yr old son could do it, like I give a ****.
Old Dec 9, 2004 | 04:54 PM
Ev0 1's Avatar
Oh, do you have a pix of the knob? Good luck with your install.
Old Dec 9, 2004 | 05:33 PM
UFO's Avatar
UFO
Hey, you're the one who posted here because they couldn't unscrew a shift knob. He's available for hire if you ever have trouble opening those pesky jars or bottles.
Old Dec 9, 2004 | 05:54 PM
mrbkkt1's Avatar
normally id bust on someone who posted this thread, but hey, at least he asks before he breaks anything. me i'm the type of person who dives straight in, run into a prob lem, and THEN check the forums for help LOL
