VIDEO of Evo on a dyno run
Old Jan 17, 2005 | 06:50 AM
  #31
thestaton's Avatar
The shop was really clean looking and I actually thought the EVO was very tastefully done. And right around 400WHP only at 21psi I think is a pretty good deal.
Staton
Old Jan 17, 2005 | 08:41 PM
  #32
leif's Avatar
you people are all blind, its a b18..sheesh learn how to read.
Old Jan 17, 2005 | 08:54 PM
  #33
boostfed's Avatar
but if you look even closer it says 84mm. that's put's in right at the 2.0L(1.96L or something close to that. I can't remember. it was like a year ago.) I used to have a similar setup block. except it had darton sleeves..... and my Si was black... I miss my Honda... I almost completed a very similar setup as the Si in the video, but I ended up selling it all and I put big wheels and tires and a lift kit on my turbo diesel.
-Chad-
Old Jan 17, 2005 | 09:00 PM
  #34
strongbear0's Avatar
Wait till you see the next video from Fernandos Integra GSR. He puts down even more with the 3 bar map sensor. His car is insane. CFT is right next to titanmotorsports.com(aka evostore.com) these guys know the microtech and fernando's teg put's down a lot more than the 501 he did at 21psi. Not to mention he runs a 11.03 with the tires spinning most of the way.
Old Jan 17, 2005 | 09:03 PM
  #35
boostfed's Avatar
I wanna see....
-Chad-
Old Jan 20, 2005 | 02:33 PM
  #36
KIDBANGA10's Avatar
I just watched the vid those numbers are very low for a gt35 and the torque is extremley low.
Old Jan 21, 2005 | 02:21 PM
  #37
sdhotwn's Avatar
Originally Posted by chapter8
MICROTECH is not bad, my old car had it...but you cant even compare it to the resolution of the evo ecu, especially if you tune it in matrix mode. You also lose knock sensor and you can forget about coldstart......if you live in TX, FL or CA your fine but if it gets under 50 degrees the provisions in the crank map are limited...prepare to swap drenched plugs often.
Its pretty archiac compared to the ecu by far.....if you want standalone get the FCON or AEM....dont waste your time on the microtech but Im not fond of standalone....unless your going with a really big turbo
Any standalone is pathetic compared to a stock ECU... but you often can't tune a stock ECU... But you can't compare a generalized EMS against something a huge motor company spent millions of dollars developing and has the entire engineering knowledge of the designers of the motor behind it.
I disagree on cold start... I've never had an issue with my vehicle... yes with poor tunes... but not the fault of the system...
The knock sensor on most stock vehicles is just shy of a joke... and relying on that is relatively foolish. If you are really concerend about knock get a JandS safeguard and you'll have more power over knock than any stock ECU is capable of...
also, keep in mind that the newer Microtech's run much better processors and can be configured to a LOT of resolutions, some over 64x64. Also, it has very powerful bezier curve fitting used... Also, the tune is a HUGE factor in the performance of the vehicle. So it doesn't matter what the EMS is, if it is tuned poorly it'll perform like crap regardless...
Not to mention not having a true custom map specifically for a car based on the dyno is even more archaic (think superchip or the like) and all that much more likely to create even less power.
As far as tuning potentional there is little difference between the modern Microtech's and the AEM's in many ways. The AEM's carry a more advanced feature pack for certain things, but the overall timing and fuel and adjustment factors that are critical to the tuning of the motor have very little difference.. Not to mention that you can fit a Microtech to a car for about 1500 or less and many AEM packages for many cars are in excess of 2000 with little overall advantage.
Old Jan 21, 2005 | 02:25 PM
  #38
sdhotwn's Avatar
And might I add I saw no sign of the laptop.. so if they tuned off the Microtech Dash Unit they should be shot.
Old Jan 21, 2005 | 08:03 PM
  #39
smp3000's Avatar
^^^^ This man knows his stuff!!
Old Jan 22, 2005 | 04:57 PM
  #40
DjRiice's Avatar
damn....one bad @$$ civic......DAMN !!!
Old Jan 22, 2005 | 05:04 PM
  #41
k.lowe's Avatar
Originally Posted by Mitchubishi
^^^I definately agree, I don't give a rat's *** about the crappy (for the vid) music as well. Those numbers were terrible for a car so modded. I would've though at least 500 whp or more? I mean the little 1.6 liter civic did 550 whp! I don't care if it's sleeved and has more extensive engine work, it's a civic !
tsk tsk such a hater
Old Jan 28, 2005 | 05:15 PM
  #42
WavMixer's Avatar
Nice Evo!!
Old Jan 28, 2005 | 05:38 PM
  #43
race17k's Avatar
that exhaust sounded nice! anyone knom wat kind it was?????
Old Jan 28, 2005 | 05:40 PM
  #44
EVIL MR's Avatar
works dp ,tp and hks catback
