Stock wastegate actuator split on me
Old Jun 7, 2005 | 09:51 PM
  #31
144mph's Avatar
while there are only two 12mm bolts that actually holds the actuator to the tubo compressor housing, you'll need to take off the lower turbo heat sheild in order to get to the cotter pin that keeps the end of the actuator rod on the flapper. That my friends, is the challenge.
Old Jun 8, 2005 | 03:59 PM
  #32
Novtec1's Avatar
Veteran: Army
hum... glad i looked at this.. guess i know what i'll be putting on next!!!!
Old Jun 9, 2005 | 06:03 AM
  #33
deadbeatrec's Avatar
how do u adjust the wastegate? like i know how to adjust it but how do i know when its adjusted?
Old Jun 9, 2005 | 07:20 AM
  #34
Mike@Forge's Avatar
Our particular actuator can use 1 of 4 different springs to allow for separate ranges of boost pressure, but each spring can be individually adjusted by turning the turnbuckle at the end of the actuator rod in towards the body of the actuator forcing there to be tension on the actuator spring to connect the arm to the wastegate lever/flapper.
By doing so, you will notice incremental increases in the boost output of the car.
(Only 2 of the 4 springs are most appropriate for the Evo application.)
The base spring for the Evo Actuator has an adjustment range of 14-18 PSI and the second level spring has an adjustment range of 19-24 PSI.
The actuators are built with the lower of the two springs and the second is not included. They are only available separately for $16 each.
We can, however, build the actuators to order with any spring you would like.
***Please note, these actuators will not increase the boost output of the car when the stock boost control solenoid is used.
The factory solenoid which is controlled by the ECU will just bleed off any additional amount of pressure you are trying to make.
This product is only useful when using an aftermarket mechanical or electronic manual boost controller or no boost controller at all.***
Old Jun 9, 2005 | 08:01 AM
  #35
ultraflip's Avatar
good morning mr. mike@forge
by any chance... would you have an eta as to when you'll have these pieces in stock?
Old Jun 10, 2005 | 12:49 PM
  #36
EVOla_VIRUS's Avatar
I believe slowboyracing sells them...in which im planning to get.....im distruting 03 Evo stock parts for some reason....hmmmm (tranny, temp dial, actuator..etc )
Old Jun 10, 2005 | 01:17 PM
  #37
Mike@Forge's Avatar
I think I have 3 or 4 in stock right now, with another 5-10 on order.
