Stock wastegate actuator split on me
Old Mar 3, 2005 | 01:36 PM
stvbreal's Avatar
The car is 2 years old with 23k miles on it. Just by looking at it
the metal looks cheap. I haven't heard this happening to anyone
else so I'll chalk this up to a build issue.
Here's the replacement part. Forge Motorsport.
Old Mar 3, 2005 | 01:52 PM
smokey's Avatar
DAMN!!!!!!!!!. Did it split on you when you were driving hard.....or just normal driving conditions? How much was the replacement?
Old Mar 3, 2005 | 01:54 PM
Theibault's Avatar
Crazy. Never seen that before.
Old Mar 3, 2005 | 01:58 PM
stvbreal's Avatar
I'm not sure exactly when it happened. First thing I noticed was I wasn't holding steady high boost. Kept spiking. Thought it was a disconnected hose. turned out it was the actuator. Replacement was $170.00 shipped overnight. He gave me a great deal. It's a nice looking piece, serviceable and gauranteed for life.
Old Mar 3, 2005 | 02:19 PM
smokey's Avatar
Who got you the deal? where did you get it from? How did you know to check the waste gate?
Old Mar 3, 2005 | 02:29 PM
bigjhoney's Avatar
jeez if it was me I probably would would of went through everything else first before checking the wg.
Old Mar 3, 2005 | 02:35 PM
smokey's Avatar
I would have kept driving like a dummie until the car broke
Old Mar 3, 2005 | 02:38 PM
UT_Evo's Avatar
Yeah, there's a release on Mitsu's tech program about the '03 Evos and how some of them may have faulty actuators... it would be covered for free if you took it to Mitsu I thought that was what my problem was (I'm running a whopping 15psi with ZERO leaks) but it wasn't but we talked all about it
eve-slow's Avatar
Are there any advantages with the Forge piece over a functioning stocker?
Old Mar 3, 2005 | 02:44 PM
tokeone's Avatar
similar thing happened to me.
the diaphram in mine spit or something. wouldnt hold pressure.
i got the forge one too (only one on the market and cheaper than stock). its a good piece
Old Mar 3, 2005 | 03:10 PM
Theibault's Avatar
I might go to the dealer and have them check mine.
Old Mar 3, 2005 | 03:37 PM
stvbreal's Avatar
I talked with Mike at Forge Motorsport. Realy great guy. Helped me out big time.
I didn't realy know to check the actuator. All I did was slightly tug on the air hose that connected to it. To my suprise the actuator was moving around like a bobble head.
Old Mar 3, 2005 | 06:07 PM
exhaust_note's Avatar
i spiked to 22.5 psi the other day, this kinda worrys me.. im gonna go try and see if i can see anything just by looking at it... anything special to look at besides the wastegate actuator....
*edit*.. i just peeked at it and it looks perfectly fine.. almost brand new.. its prolly ok...
Old Mar 4, 2005 | 10:15 AM
stvbreal's Avatar
Got the part in today. Great looking piece! ! Weighs slightly less also. I'll be installing later today. Here's some pics.
Old Mar 4, 2005 | 10:22 AM
tokeone's Avatar
a quick way to check your actuator is get a bicycle pump with a pressure gauge
connect it to your actuator and pump in a few psi (dont go over stock boost. you can just pump in like 5psi)
the actuator should hold the pressure.
if it doesnt, then you probably have a problem
the only gripe i have with the forge is (as you can see from the pictures above)
the nipple in is slightly bigger than the stock.
it just makes squeezing the hose on a little more challenging.
